Big foot leaf springs - Fiberglass RV
Old 10-30-2014, 12:39 PM   #1
Trailer: 17' Big Foot
I'm looking for replacement leaf springs for my 1983 17' BFF. Does some one have a part # and dealer name?
It would be easier this way than to repair the ones I have. I've called Big foot and told me to call Standens in Alberta. They gave me some numbers but they seem to long. I've sent Emco IND an email, but no response.
Thank you.
Jeff T H is offline   Reply With Quote
Old 10-30-2014, 12:44 PM   #2
Trailer: Bigfoot 17' DLX
Alaska
I would have a Standens or Dexter dealer look at and measure your originals and have them order the replacement parts. That way, if there is a mistake, it's on them.
trainjunkie is offline   Reply With Quote
Old 10-30-2014, 12:46 PM   #3
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Try etrailer or a local spring company. We have Albany Spring up the road in Albany NY and they will make leaf springs or coil springs to spec. Basically for leaf spring they need eye to eye measurement and number of leafs, at least, that's what I think they go from. I've had them make leaf springs for me for a boat trailer years ago and I was surprised how reasonable the cost was.
Best of luck to ya!
Frank
2012 ParkLiner #006
Old 10-30-2014, 02:15 PM   #4
springs
Thanks for the feed back. I was reading a thread from you trainjunkie from last year. You had problems with your springs and had a replacement shipped to you. You posted a part number. And mentioned Emco ind.
I was just hoping there was a readily available spring off the shelf.
I will find a spring manufacture and hopefully they will help.
Thanks again.
Old 10-30-2014, 02:42 PM   #5
I took the easy way out.....
I took it to a spring shop (Courtenay Spring)...550 bucks...
1994 BF 17CB
Old 10-30-2014, 02:51 PM   #6
Alaska
Thanks again.
There probably is an off-the-shelf spring that will fit your BF but I strongly suggest you have a shop do the measuring and order the springs if they don't already have them. I wouldn't bank on different year Bigfoots having the same springs, or even ones of the same year, so don't trust some other BF owner's part numbers.
I would just have a shop get all the critical dimensions to make sure you get the right springs. Or, go the route Francois did and have them made. Looks like his shop there in BC did a good job.
Shocks and/or leaf springs on Casitas Donna D. Modifications, Alterations and Updates 20 05-02-2014 09:57 PM
Trails West Campster Dry Weight- replacing leaf springs Rpryor3 Towing, Hitching, Axles and Running Gear 7 06-13-2013 06:07 AM
torsion springs or leaf springs Cat futrell Problem Solving | Owners Helping Owners 18 08-26-2012 08:12 AM
Leaf Springs, maybe axle? Bobbie Mayer Towing, Hitching, Axles and Running Gear 10 02-20-2008 09:49 PM
How often do leaf springs fail? TonyB Towing, Hitching, Axles and Running Gear 11 01-11-2008 09:40 PM
