Big foot widows - Fiberglass RV
Old 07-01-2019, 09:47 AM   #1
Trailer: Big foot
Big foot widows
Looking for help in replacing my side window of my 1985 Bigfoot the widow doesnít appear to want to came out it there any secrets
Hairy Bigfoot is offline   Reply With Quote
Old 07-01-2019, 10:33 AM   #2
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
All the screws are out?
You want to have a person helping if possible, to make sure it doesn't fall out. But once the screws are out, it's just a matter of working it out of there. A putty knife or something similar to gently pry helps.
Since it's been in there for 30+ years, it's pretty well stuck in place. Shouldn't take too much persuasion to get it to separate, though.
Old 07-29-2019, 08:30 AM   #3
Trailer: 2004 17ft CB 1500 Bigfoot
Bigfoot widows
Harry, did you get them out? I just removed the windows on my 2004 17 ft, took them out of the frame, resealed the thermal units and put them back. I ended up getting a "dull knife" about 6 inches long and used it as a pry bar. Easing the knife in behind the frame every few inches and prying out. Slow and steady and till it pops. It does not hurt to heat up the knife a little to help get through the black window sealant. Any small marks on the fibreglass are behind the frame on reinstall. Not sure I would do it again, a lot of work!!! Would buy new windows from Sunview Windows in Summer land B.C. Good luck! Cheers, trapper
trapper is offline   Reply With Quote
Old 07-29-2019, 09:33 AM   #4
Bruce H's Avatar
Trailer: Bigfoot 25 ft RQ
When I had to replace some windows in my previous Bigfoot 21FB I went on the internet and ordered some non-marring auto body trim tools (various shaped plastic? pry bars) from an auto body tool website. Not very expensive but not the kind of thing you find at Walmart or Target. I also ordered a heat gun with a digital temperature readout. A hair dryer will not get hot enough but a heat gun can get too hot and set things on fire. That is why the digital readout model to adjust the temperature. Even with all of that, it is not easy to get the old dry sealant loose. Doable but not easy.
Old 07-29-2019, 01:57 PM   #5
I used a small 90 degree bent angle O ring pick hook to dig out the old putty tape that was keeping the windows stuck to the shell. Part of the job of removing windows is to somehow break that bond of the old putty tape. As you can see by the responses there is more than one way to do it and sometimes it takes a combination of tools to get it done.
But that strong little bent hook worked very nicely. They are not expensive and can be found at hardware and auto parts stores.
bigfoot
My Big Foot lost his Foot RV NUT CASE Problem Solving | Owners Helping Owners 15 03-24-2017 12:54 PM
OH | 2008 25 Foot Big Foot For Sale $24,500 Boomer Classified Archives 12 02-07-2014 01:26 PM
OK | 2008 25 Foot Big Foot For Sale $24,500 Boomer Classified Archives 0 07-11-2013 05:39 PM
SOLD 1986 Big Foot - 18 foot on EBAY Dave Baston Classified Archives 31 01-16-2008 06:41 PM
