BIG HOLE IN ROOF ( Boler ) - Fiberglass RV
Old 04-05-2013, 09:22 PM   #1
Trailer: 1974 boler 13ft
Hi everyone , it's been awhile since i have signed on here , i have a question that's been bugging me for a few years . I have a 1974 Boler ; it was given to me by a nice old lady ; her husband passed away and she had no use for it . It was a true fixer upper . The guy cut a 2' x 3' hole in the roof , he used the camper as an observation station for astronomy . My question is how do i fix the roof with the compound curve with fiberglass for a perfect flush finish . I will upload a video tomorrow . Any help will be greatly appreciated .
trailerlust is offline   Reply With Quote
Old 04-06-2013, 07:05 AM   #2
GMike A's Avatar
Originally Posted by trailerlust View Post
Hi everyone , it's been awhile since i have signed on here , i have a question that's been bugging me for a few years . I have a 1974 Boler ; it was given to me by a nice old lady ; her husband passed away and she had no use for it . It was a true fixer upper . The guy cut a 2' x 3' hole in the roof , .
I dont think it will be as bad as you think if you are willing to tackle it. There is a great thread on FiberGlass Repair that David White put together. Using the patch technique I feel it would work fine. Check this link
You Can Repair Fiberglass.
Im sure he will chime in but am thinking out loud to make a flat patch on the ground to approximate the size, let it cure of course and then mount it like he has done on the vertical holes that he shows how he fixed.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 04-06-2013, 07:23 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Yo can also buy fiberglass sheets that can be cut to fit the hole and then patched in using mat and resin.
McMaster-Carr
A second alternative would be to buy a telescope.
Old 04-06-2013, 07:31 AM   #4
GMike A's Avatar
Thanks Tom, Learned something new. Wasnt aware that you could buy pre-made patches. Im almost ready to tackle mine soon. I sprayed the entire insides of mine with an acetone/xylene mixture to try and get the last segments of that stubborn contact glue off.
Perry there are a lot of good instructional videos on YouTube also under fiberglass repair. I have watched several hours worth from different submitters and have gotten some good ideas to work with. Good Luck and take Pictures for the forum of what you did.
Mike
K5NAN
"Miss Adventures"
Old 04-06-2013, 08:03 AM   #5
Roy in TO's Avatar
Originally Posted by GMike A View Post
... I am thinking out loud to make a flat patch on the ground to approximate the size, let it cure ...
I'd suggest trying to match the curve on the ground or even on the roof using something flexible - then patching. Less likely to end up with a flat spot on the roof.
Old 04-06-2013, 08:19 AM   #6
Thomas G.'s Avatar
Good point. If you could find a good spot on the roof with similar curvature, you could put a covering on it (clear packing tape or mold release wax?) and make a patch from mat and resin.
Old 04-06-2013, 11:28 PM   #7
Thank you all for great sources of information ; i will look into all suggestions .
Old 04-07-2013, 09:58 AM   #8
D White's Avatar
Trailer: Trails West Campster, CampStar, Uhaul, Fiberstream
Grind the edge back 4 inches, then I would buy a piece of formica larger than the hole by at least 6 inches (the bigger the better because it will help getting the right shape), cover it with wax paper, and use some drywall screws and some scrap lumber and to push up from the floor gently to mimic the curve for support and screw the edges (outside of the ground area). Probably need a friend to help you. After your "mold" is fully supported, cut 3 pieces of mat, 1 to go clear out to the ground edge, 1 an inch smaller and the final one an inch smaller than that.
Saturate and fully roll resin in the 3 layers of mat going from large to small. Try to make it as smooth as possible. Use 36 grit sandpaper stapled to a piece of 2x4 to sand level after cured. It is best to sand sooner rather than later as the patch becomes harder the longer it cures. Filler is next, then primer and paint. This is a more difficult repair, but you can do it, just keep at it...if your not happy with it, you quit too soon is our moto here...couple more things...the screw holes need to be ground and filled with mat before filler, and you need to wear safety equipment as described in the thread....Dave (I am available by phone if you need to, just pm me)
I feel this description is to over simplified and poorly written....but I also believe you can do this patch better than I can describe it...please pm me for a phone conversation
D White is offline   Reply With Quote
Old 04-07-2013, 10:22 AM   #9
GMike A's Avatar
Dave for my education and not necessarily Perrys. I would grind the top surface area back around the perimeter (exposing FG) about 4 inches and then after my "form" is secured from the inside then I lay the resin coated mat down on the top and build it up. And then you build those 3 strips up or out to make a smoother surface plane around the perimeter of the mat that I laid down in the middle of the formica form.
Mike
K5NAN
"Miss Adventures"
Old 04-07-2013, 10:25 AM   #10
GMike A's Avatar
One more FG question. I see some Eggs that the FG is cream yellow;however, mine is black where I have been able to remove the contact cement from. Do I have to sand or do something to get to the "yellow" state or are some Fiber Glass constructions just a different color??? Hope thats not too dumb of a question.
Mike
K5NAN
"Miss Adventures"
Old 04-07-2013, 10:38 AM   #11
D White's Avatar
Yes, I see I was not clear...the formica goes on the INSIDE of the hole and needs support from the inside with scrap lumber....sorry....Dave
Old 04-07-2013, 10:47 AM   #12
D White's Avatar
I would need lots more information, but the black sounds like an applied coating of something like paint or glue???? There is black resin used in making molds and parts, but I have never seen it in the trailer industry....course, who has seen it all right???
Old 04-07-2013, 10:51 AM   #13
D White's Avatar
Originally Posted by D White View Post
Yes, I see I was not clear...the formica goes on the INSIDE of the hole and needs from the inside with scrap lumber....sorry....Dave
The mat needs to be bigger than the hole and the formica will be removed after cure....I see that I have poor writing skill and have left much information too simplified....sorry...I hope the original poster would pm me and we'll go over it on the phone....
Old 04-07-2013, 12:52 PM   #14
GMike A's Avatar
No it made sense and your writing skills were fine. I wanted to make sure that the gelcoat on top was removed 4 inches all the way around and of course on the bottom side has to be down to bare FG. I was just drawing a big picture in my mind. As you have indicated several times if it isnt right then cut it out and start over. Thats the beauty of FG to paraphrase you.
Mike
K5NAN
"Miss Adventures"
boler
Anyone know how to fix a saggy roof in a Boler??? (around roof vent) idiotsniff Problem Solving | Owners Helping Owners 31 11-17-2014 06:50 AM
Mounting things on roof w/o drilling a hole stev Modifications, Alterations and Updates 26 10-21-2012 01:59 PM
Large hole in roof trailerlust Problem Solving | Owners Helping Owners 15 12-15-2011 09:29 PM
13 foot Boler too big! I'm downsizing. Matt, H General Chat 5 08-10-2009 01:11 PM
Roof vent and big window finally in!! Pamela H Problem Solving | Owners Helping Owners 4 08-20-2008 11:38 AM
