Bigfoot 17' 1986 Air outlet 9" X 9" in bathroom roof. - Fiberglass RV
Old 06-10-2015, 11:06 AM   #1
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Which would be the best solution to fix Maxxair to an exit of 9 inches on the roof of the bathroom ?
Maxxair has only a single size, fit well on 14" X 14".
I think of going and fetch me aluminum with angle
of 90, high of 1" X 2"(flat) and 15" lenght.
Fix it with the present screw of vent...
What is your opinion on that?
Thank you,
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 06-11-2015, 09:48 AM   #2
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Mounting a 14" fan would require rather drastic roof cutting and I don't think I'd try it.
Another idea would be to make a mounting bracket to fit your opening with this fan.
Ventline Vanair Trailer Roof Vent w/ 12V Fan - 6-1/4" Diameter - Smoke Ventline Enclosed Trailer Parts VP-543SP
Good luck on your project.
Walt
Old 06-11-2015, 08:24 PM   #3
Trailer: TBA
Wisconsin
Walt
Ummmm Walt,
Just below the specs on the fan you posted is this: Note: Not for use above tubs, showers or range cooking surfaces.
Badger is offline   Reply With Quote
Old 06-11-2015, 09:02 PM   #4
WaltP's Avatar
SW Virginia
Ummmm Oops. Sorry.
Old 06-11-2015, 09:16 PM   #5
Gilles's Avatar
Quebec
At this moment I decided to adapt only Maxxair on the ventilator of roof of 9 ", to be capable at least of leaving opened without rainy danger in the bathroom.
I installed 2 parts aluminum of 1.5" X 15 " every.
Made a template with a part of plexiglas.
Change the old screws for stainless steel screws.
Put some silicone in the old holes of screw before installing the news, stainless steel, in same location.
Straighten angles aluminum to attach them at the part of aluminum.
See pictures.
Gilles
Bigfoot 15B17G.
Old 06-11-2015, 09:27 PM   #6
Trailer: TBA
Wisconsin
Looks nice Gilles
Old 06-11-2015, 09:30 PM   #7
I'm thinking....
a MaxAir fan is A LOT of fan for a bathroom....like way too much....
I'm going to assume that your "new to you" bathroom was not equipped with an exhaust fan....just the standard little opening roof vent.....
my PO added a MaxAir cover over that vent...so it could be left open while travelling dwon the road.....(still no fan...but the standard roof vent could be left open all the time)
I added a 12V computer fan (wired to the bathroom light).....it moves air (creates negative air pressure in the bathroom).....might not be "perfect" but it does the job....(I also removed that big offset "crank" with a flush wheel for a little extra headroom.....from a water supply valve to a sink)
just some ideas....
Old 06-11-2015, 09:33 PM   #8
Gilles's Avatar
Quebec
Thank You Rick.
I'll look later, how make a 14" hole, with no danger to brake nothing, and install an electric fan...
Gilles
Bigfoot 15B17G.
Old 06-11-2015, 09:34 PM   #9
too funny.....posting in real time !!!!!
when I started my last post the last two were not there.....thought I had screwed up......yeah nice job....and exactly what my PO did.....cheers, F
Old 06-11-2015, 09:41 PM   #10
Gilles's Avatar
Quebec
just some ideas....
Thank You for all these ideas Francois.
Have a good night, here it's 11:40 pm
Gilles
Bigfoot 15B17G.
bigfoot
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
Bigfoot: Enlarging bathroom vent from 10" to 14" pindraak Problem Solving | Owners Helping Owners 11 06-02-2012 11:07 AM
"HOT" Propane Guage Buy at Grocery Outlet Francesca Knowles General Chat 21 05-23-2011 08:27 AM
Bigfoot rv factory outlet Ken C General Chat 3 07-15-2010 06:24 PM
Roof air for a 1981 17' Bigfoot GHYNES Problem Solving | Owners Helping Owners 1 09-13-2009 04:14 PM
