Bigfoot 17.5 trailer uneven side-to-side - Fiberglass RV
Old 05-15-2019, 10:04 AM   #1
Trailer: Bigfoot 17G
I have never really looked at my 1995 Bigfoot trailer on perfectly flat ground but did so the other day. It looked a little lower on one side than on the other so I measured and discovered that the left (kitchen) side is 1" lower than the right side.
I'd appreciate hearing some opinions as to whether this should be considered as a problem and, if so, what possible causes and solutions might be.
Thanks in advance to all who respond.
bobblangley is offline   Reply With Quote
Old 05-15-2019, 10:36 AM   #2
FRED SMAILES's Avatar
Trailer: 13 ft Boler
My boler is like that too with a new axle. I attribute it to being heavier on that side on my unit.
Fred
FRED SMAILES is offline   Reply With Quote
Old 05-15-2019, 10:37 AM   #3
ZachO's Avatar
Trailer: Sasquatch
Montana
Not a big deal, but definitely worth doing something about. The way these are built, everything is on that left side. Bathroom, waste tanks, stove, furnace and fridge. The only way to balance the load is to have a full freshwater tank (at least on my 91).
When I upgraded my axle, the trailer shop swapped the springs. He took the left springs and put them on the right, right springs on the left. This leveled out the trailer. You can also put all new springs on, if you want.
Or you can ignore it.
Old 05-15-2019, 10:46 AM   #4
David B.'s Avatar
Trailer: Former 13’Scamp, now Snoozy
Since roads are built with a “crown” for drainage, then having a 1” lower driver side would tend to level out the trailer while going down the road.
Dave & Paula
Old 05-17-2019, 05:52 AM   #5
Doug Arthurs's Avatar
I would just take a look under that side and make sure there are failures. Stuff to look for would be broken spring, crack or rust on frame hanger broken spring hanger lots of stuff to be aware of. Could be nothing too but doesn't hurt to look around.
Doug Arthurs is offline   Reply With Quote
bigfoot
Trailer rocks when towing over uneven road surface- time for new springs or? Cathie Sadler-Pare Towing, Hitching, Axles and Running Gear 42 11-18-2015 09:57 PM
uneven tire wear outthere Problem Solving | Owners Helping Owners 7 07-10-2013 07:21 PM
Uneven tire wear on one side Bobbie Mayer Problem Solving | Owners Helping Owners 12 06-01-2010 05:28 AM
Uneven tire wear Tamid Towing, Hitching, Axles and Running Gear 6 03-29-2010 11:13 AM
Uneven trailer braking John & Sandy M Care and Feeding of Molded Fiberglass Trailers 15 02-03-2007 01:18 PM
