Bigfoot 17 Electrical Problem AC yes DC no?? - Fiberglass RV
Old 11-12-2014, 07:45 PM   #1
Trailer: Bigfoot 17
I have a 1990 Bigfoot 17.
The AC is working but not the DC.
I get 12V DC from the fuse panel on the Power Converter. But no where else.
I figure that I must have a bad ground somewhere.
Anybody know where to look for a bad ground ???
hoppy1962 is offline   Reply With Quote
Old 11-12-2014, 07:57 PM   #2
FTTRV's Avatar
Trailer: tp
Look for a fuse from the battery maybe under battery box or in and around hitch area.
Chuck
Old 11-12-2014, 08:04 PM   #3
My 94 Bigfoot has an inline fuse between the battery and panel. It's located under the dinette seat along the front bulkhead an it is a 30 amp glass fuse in a black fuse holder.
Jack L is online now   Reply With Quote
Old 11-12-2014, 08:19 PM   #4
Trailer: Bigfoot 17
Found the 30 amp battery fuse. Tested it and the other ones on the power converter. Their all good and still no DC.
Old 11-12-2014, 08:27 PM   #5
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Would it not be simpler/easier to just run another ground wire rather than to look for the one that might not be good?
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 11-13-2014, 10:01 AM   #6
Fill an old coffee can with dirt and place it under the bed and you will have a new ground.
Old 11-13-2014, 10:02 AM   #7
Look for the ground wire from the converter to the frame. Could have corroded off.
Old 11-13-2014, 11:03 AM   #8
Did you put a tester on the wire going to the fuse? Any power to it?
Not sure about the older Bigfoots but some trailers (mine included) have two inline fuses - on right off the battery outside and another inside the house.
Old 11-13-2014, 06:14 PM   #9
Dan Meyer's Avatar
What brand and model is your power converter?
-- Dan Meyer
Old 11-13-2014, 06:17 PM   #10
Trailer: Bigfoot 17
I went through the trailer testing all the ground wires with an Ohm meter and a Pin.
They all tested good. So I plugged in the trailer to my AC wall outlet and abracadabra! I have DC again. Don't know why. Probably wiggled a loose wire tight again. Thanks everybody for all your help.
Tom
Old 11-13-2014, 07:14 PM   #11
Tom
Humm are you sure you actually have DC power again? if your plugged into a 110 wall outlet your getting your power via the wall outlet and converter not the battery. If your lights do not work when not plugged into the wall outlet you still have a DC power issue.
Old 11-13-2014, 10:16 PM   #12
Joe Z's Avatar
New River AZ
try disconnecting the battery posts, plug in the converter to 110 ac and test with a multimeter the wires at the battery while it's disconnected and see if power is getting to there
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 11-14-2014, 10:05 AM   #13
Trailer: 2008 Casita 17 SD
Pull your battery out and take it to your local auto parts store. Have them do a load test on it (it's usually a free service.) I'll bet your battery is shot and needs to be replaced.
bigfoot, electrical
Yes!! A Great Vented Catalytic Heater S Sato Modifications, Alterations and Updates 35 02-06-2017 11:41 AM
Would you say yes or no? Steve Dunkel General Chat 14 08-10-2009 07:05 AM
Ahhh yes.. Gods Country.. The Pacific NW! Christi V. Jokes, Stories & Tall Tales 14 01-27-2008 11:09 PM
Yes... People DO Steal Trailers! Buck62 General Chat 11 01-14-2007 10:43 AM
Oh Yes!!! Picked up my egg this morning!! Mike H. General Chat 8 07-12-2006 05:18 PM
