Bigfoot 1986, Newtec PGD 7 ? - Fiberglass RV
Old 06-07-2015, 05:11 PM   #1
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
I have a thingy which is called Newtec, with 2 wire who are going to connect in the transformer.
An on/off switch in the front accompanied with a mini-led red.
In the back a not is written, to put the switch in off so more than a week than the battery is not any more on the automatic load.
Can anybody explain me the utility of this thingy?
See the picture.
Thank You,
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Gilles is online now   Reply With Quote
Old 06-08-2015, 11:12 AM   #2
Gilles's Avatar
Quebec
I find nothing on Web about this device.
Gilles
Bigfoot 15B17G.
Old 06-08-2015, 11:33 AM   #3
I suspect PGD stands for Propane Gas Detector.
If that is the case, it would be hard-wired like that.
And, it would be well beyond its useful life of about 5-7 years.
I would remove and replace ( as I just did - not cheap for MTI brand detector at $120 )
MTI Industries, Inc.
Old 06-08-2015, 05:40 PM   #4
Gilles's Avatar
Quebec
I see no indication to indicate that it is a gas sensor, except for the abbreviation as you see.
Even the last owner was not able to answer me, out of curiosity he asked me to give him the answer if I find the utility of this thingy.
I did not want to disconnect without knowing little, to not removing any control.
That seemed to me the most likely and I am going to replace by a new.
Thank you Glenn to rest my intuition.
Gilles
Bigfoot 15B17G.
Old 06-08-2015, 06:05 PM   #5
Found an old PDF of the owner manual for a Winnebago that mentions Newtec Propane Gas detector. There is that grillwork to allow air ( and propane to enter ). I'm quite sure that's what it is.
Where is it located in the trailer. If it's near the floor, that's where a propane detector is supposed to be, because propane is heavier than air.
Old 06-08-2015, 07:43 PM   #6
Gilles's Avatar
Quebec
Merci Glenn,
The floor, and under the table in the front of the caravan is placed well.
It is certainly a gas sensor propane.
Gilles
Bigfoot 15B17G.
Old 06-09-2015, 07:35 AM   #7
Trailer: 2017 Escape 19
Gilles, glad you got an answer. Amazing the things people know on this forum. You could replace it with a combination CO/Propane detector.
Evergreengirl is offline   Reply With Quote
Old 06-09-2015, 08:19 AM   #8
Gilles's Avatar
Quebec
Thank you Kathy for the good idea, to combine CO / detector Propane.
Have a good day.
Gilles
Bigfoot 15B17G.
Old 06-09-2015, 04:13 PM   #9
Gilles's Avatar
Quebec
Have a good day.
Kathy,
I spoke with my supplier of equipment for caravan and he told me that if I do not use a generator, as to camp savage, only that of the propane is necessary...
Gilles
Bigfoot 15B17G.
Old 06-09-2015, 08:46 PM   #10
Perry J's Avatar
Trailer: 16' Casita
Kathy,
What happened if your gas heater fire box springs a leak or you somehow get some fumes in the cabin from your gas refer?
Old 06-09-2015, 09:20 PM   #11
You just ignore it. Easy enough to do when you are unconscious.
Old 06-09-2015, 09:45 PM   #12
Trailer: Bigfoot B-17 CB
Or your stove!!!
Old 06-10-2015, 05:29 AM   #13
Gilles's Avatar
Quebec
Thank you for your interest on the security of the campers.
I consider good that I am going to follow your advice.
A few more is better that just not enough...
Have a good day and sleep peacefully.
Gilles
Bigfoot 15B17G.
Old 06-20-2015, 03:27 PM   #14
Gilles's Avatar
Quebec
After this discussion, I replaced the old gas sensor propane by a new which detects " Carbon Monoxyde and Propane Gas, near the floor and a smoke sensor on the top.
Gilles
Bigfoot 15B17G.
bigfoot
Delamination on 1986 Bigfoot Tim D. Problem Solving | Owners Helping Owners 27 10-08-2009 09:29 AM
20' 1986 Bigfoot 5th wheel Dana T Classified Archives 1 04-27-2009 10:25 PM
Need replacement light caps for 1986 Bigfoot FredericL Problem Solving | Owners Helping Owners 1 04-08-2009 09:08 PM
SOLD - 1986 Bigfoot Spiritwing 19 ft For Sale Len S Classified Archives 8 04-07-2009 08:29 PM
Awning for 1986 Bigfoot TT...? FredericL Problem Solving | Owners Helping Owners 3 07-02-2008 04:02 PM
