Bigfoot, cabinet door cut, paint with what? - Fiberglass RV
Old 05-08-2017, 03:35 PM   #1
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
Bigfoot 15B17G 1986
Someone has already cut or trim a Bigfoot cabinet door?
The material in the door is like a highly compressed foam.
To paint the end, where I cut, I wonder what kind of paint I should use?
Thank you for your answers,
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 05-09-2017, 01:16 PM   #2
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
paint
I have painted foam with a lacquer paint and it will melt the foam. lowering the surface + or - an eighth inch. use enamel for best results. ( I think ). If there is a face surface and a back surface, one could cut a small layer of foam out, leaving a 1/8" slot from left to right at the bottom. cut a piece of wood to the size of the opening length and width lets say 1/8" by 7/16" by 16". put in place with a super glue. but it must not melt the foam. Hobby lobby may have some of this glue. or at a radio control hobby shop. It is expensive. a good wood glue should work. edge banding scrap from a cabinet shop, ( that they give you ) will stick in place with contact cement. it might have a self adhesive on the back side.
wish you luck
Later Kenny
Kenny Strong is offline   Reply With Quote
bigfoot, paint
Cabinet doors or No cabinet doors? openthegates Problem Solving | Owners Helping Owners 29 07-28-2016 04:43 PM
Andersen Hitch - No Need to Cut that Bigfoot Propane Tank Cover! Jay Moeller Towing, Hitching, Axles and Running Gear 11 06-19-2014 09:17 AM
13' boler Kitchen cabinet paint mposehn Modifications, Alterations and Updates 0 05-20-2014 06:23 PM
