I'm wishing my 21RB didn't even have front window and rock guard. I found the ALUMINUM 1/8 inch pop rivets that BF secured the hinge to the top of the rock guard breaking. 6 of the 14 were broken one end one was just hanging on.
I removed the broken pieces and used aircraft sheet metal mechanics spring Clecos to pull everything back together. Then I drilled out the remaining rivets and installed spring clecos. When done, I one at a time upsized the holes so a 8-32 thread screw would pass thru the hole (#10 drill) and installed bigger clecoes as I went. When done, I installed stainless truss head 8-32 screws and aircraft self locking nuts and washers on the inside.
The cause of all of this is those stupid gas cylinders, and the rubber T latches. The gas cylinders are 40 lb version, so that is 80 lbs total pushing straight down on the rock guard when closed, then add the pull of the rubber latches.
I have permanently removed the gas struts and do not open the rock guard. If I could find some sort of sliding strut that could be pinned it would be great.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
