Bigfoot Interior Panel Access - Fiberglass RV
Old 02-14-2012, 02:55 PM   #1
Roger M's Avatar
Trailer: Bigfoot 25B175CB
Has any Bigfoot 17 or other Bigfoot owners with a front dinette ever removed the lower front panel in the dinette area? I would like to install 110v, 12v receptacles and a Trimetric battery monitor parallel to the existing 110v outlet before removing parts I might not need to remove.
The only obvious thing to remove is the table brackets which are screwed into a stud behind the front panel.
Roger M is offline   Reply With Quote
Old 02-16-2012, 04:32 PM   #2
I have Bigfoot 21' but have never removed this panel. I did run wires behind this front panel. I was able to access wires through a storage cabinet on the street side front corner. If you remove 110V outlet you should be able to see what is behind the panel and install 12V and meter without removing the panel.
George.
Old 02-20-2012, 08:19 PM   #3
Roger M's Avatar
Like you said, snaking wires behind the panel to the electrical area without removing the panel seems to be the best option. The construction looks like it would not go back together too well after removing it.
Thanks George for your input!
bigfoot
Interior Panel Replacement Shaidah Modifications, Alterations and Updates 4 01-31-2012 09:20 PM
Bigfoot Propane Bottle Cover Access Tim D. Modifications, Alterations and Updates 2 04-17-2011 05:57 PM
missing an access panel Billb Problem Solving | Owners Helping Owners 2 05-12-2008 07:43 AM
Bigfoot 17' Roof Access Norm Wyndham Problem Solving | Owners Helping Owners 3 07-10-2007 07:20 AM
Outside access panel for Scamp & eletrical mods Ron Gaillot Modifications, Alterations and Updates 7 09-20-2006 08:24 AM
