Bigfoot trailer backup lights not working - Fiberglass RV
Old 04-26-2008, 03:30 PM   #1
Trailer: 1991 17 ft Bigfoot / 2005 GMC Sierra
Hi,
We were lucky enough to have the old owner tow our trailer to our house - so we know the backup lights on the trailer work - but when we hooked up our truck to the trailer the clearance lights and brake light function but not the backup lights. We had our Mazda truck changed from a 4pin to a 7pin so is it wired wrong? Any suggestions?
Carol Crawley is offline   Reply With Quote
Old 04-26-2008, 03:51 PM   #2
Gina D.'s Avatar
West Coast USA
Back up lights are one of the common "Options" for the auxiliary pin on a 7 pin connector. If your car was not wired for back up lights on the aux pin at the time of the 7 pin installation, that could explain your problem.
I have a 7 pin connector, but nothing is wired to my aux pin.
Old 04-26-2008, 07:46 PM   #3
Pete Dumbleton's Avatar
Gina's right! BU lights are an option on the 7-pole connector. The wire from the truck goes to the yellow center wire on the connector.
Note: If you are going to run more than just the two bulbs in the trailer fixture, consider adding a relay on the truck to handle the load and not stress the truck wiring.
Old 04-26-2008, 08:39 PM   #4
Thank you Gina & Pete for the information - I called the RV place where I got the wiring installed and you are right it was an option - they told me a lot of the older trailers & tent trailers dont have backup lights so they didnt wire it in. I assume I dont have to have them.
Old 04-26-2008, 09:56 PM   #5
Gina D.'s Avatar
West Coast USA
You would have to check your local laws, but I don't know of anywhere where it is a requirement for a trailer.
I can't really think of a reason for them, unless you do a lot of nite backing. In the rare case where I need light back there, I set out a flashlight, or even turn on the rear cabin lights and open the curtains. The side light outside by the door can be used as a runway marker on my trailer, I have used it before too.
Old 04-26-2008, 10:37 PM   #6
The reason I mentioned the relay was because I was considering using a tractor floodlight mounted on the trailer bumper as an aid when backing into totally dark campsite.
bigfoot, lighting, lights
Trailer Fridge now Working Properly Rick G Care and Feeding of Molded Fiberglass Trailers 3 01-15-2013 07:49 AM
Running lights not working DavidS Problem Solving | Owners Helping Owners 2 09-06-2009 10:15 AM
1993 Bigfoot 17ft - tail lights LeanneH Problem Solving | Owners Helping Owners 2 09-22-2008 06:20 PM
DC lights working with no battery connected???? dora D Problem Solving | Owners Helping Owners 4 10-10-2007 06:17 PM
Backup Power? Art Davis General Chat 3 03-23-2007 08:04 PM
