bigfoot wallpaper - Fiberglass RV
Old 06-18-2007, 10:59 PM   #1
Ericpa3's Avatar
Trailer: Bigfoot 17 ft Gaucho
We were camping on the coast this weekend and had left the outdoor grill at home, so I used the rear left burner to fry. I put a sheet of aluminum foil over the pan to keep the grease from spattering. The wallpaper on the left wall near the rear burner blistered from the heat.
Anyone seen this before? Have you used your rear left burner on relatively high heat? Was it heat deflected leftwards by the aluminum foil?
I'd appreciate any thoughts --- Roger H?
thanks
Eric
Ericpa3 is offline   Reply With Quote
Old 06-19-2007, 05:11 AM   #2
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Eric, I seldom use the rear burner... no help here...
Roger
Old 06-19-2007, 05:35 PM   #3
CharlynnT's Avatar
Trailer: Boler 17 ft
I had to go out to the Boler to look -- we have some sort of brown laminate sheeting there, cut to fit. I use the rear burner on high all the time (heating water for dishes, etc.) and have had no problems - so far! (Knock on fake wood.)
CharlynnT is offline   Reply With Quote
Old 06-19-2007, 05:37 PM   #4
Trailer: 1991 Bigfoot 17 ft
thanks
Eric
Hey Eric ! I have had two similar incidents that were from previous owners with two different trailers...I'm not sure if it was your tin foil or not but here's what I did to fix it. I went to my local dollar store and bought some tin tiles or trivets. They look like shiny stainless tiles. I removed the old wallpaper and replaced it with faux stainless steel contact paper available at Home Depot or even Walmart then I glued the tiles on the contact paper with a product called Weldbond....It looked great and modern...and I haven't had any other issues since. The back of these tiles are cardboard covered by the metal...Lightweight and clean up in a snap.I'll hunt and see if I have a photo to post...happy trails Mitch
mitch is offline   Reply With Quote
bigfoot
Wallpaper Francine P Problem Solving | Owners Helping Owners 6 11-05-2008 01:19 PM
bigfoot wallpaper Ericpa3 General Chat 0 12-31-1969 07:00 PM
