Bigfoot Water System Question - Fiberglass RV
Old 07-02-2018, 03:50 PM   #1
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
I remember, somewhere buried in some other thread, someone mentioning a grey water tank overflow valve. So if you over fill, you can drain some and not drive around with water sloshing around on the bathroom floor.
I found a valve connected to a hose sticking out the bottom of my camper, right under the bathroom by the grey tank. The valve is in the outside storage compartment right next to the bathroom. I figured that's what it is. But if I open it and turn on the water pump, it just pumps water out that hose.
Anyone know what's up with it? It's obviously connected to the fresh water, not the grey water. I can't think of what purpose it would serve, unless it's somehow used in winterizing.
Old 07-02-2018, 04:09 PM   #2
I have a valve for draining my freshwater tank under the trailer jus forward of the wheel well left side.
Jack L is online now   Reply With Quote
Old 07-03-2018, 07:44 AM   #3
ZachO's Avatar
Montana
Hmm. I have a drain valve at my fresh water tank. This one is behind the driver side wheel, opposite side of the trailer from the fresh tank. Wish these things had better manuals...
Old 07-03-2018, 09:21 AM   #4
Paige C.'s Avatar
Bigfoot water drain system
I have a fresh water valve drain only as far as I know in my 1994 Bigfoot 17. But couldn't you open the large grey water valve while leaving the main dump cap on so only about a quart is released, then close the grey water valve, take of the big cap and drain the quart or so. Keep doing it until you are no longer sloshing around in the bathroom floor. Seems like that could work.
Paige C. is offline   Reply With Quote
Old 07-03-2018, 07:17 PM   #5
ZachO's Avatar
Montana
I agree that would work. And in emergencies, I’ve opened the grey valve just long enough to let a quart or so out.
Still wonder what the hose is for, but it’s not much of a concern in the scheme of things
Old 07-03-2018, 09:19 PM   #6
A fresh water tank has a drain valve for two reasons. One is winterizing the other is for sanitizing so you can fill the tank with a stronger santitizer mix such as bleach, drain, rinse, repeat, rinse again and after getting all the crud out fill with fresh drinking water. At the end of a vacation trip you can empty the fresh water tank and then before the next trip put in new water. It certainly does taste better that way than drinking water that has been sitting in there for a number of weeks or months.
Old 07-04-2018, 08:17 AM   #7
ZachO's Avatar
Montana
I definitely see the reason for the tank drain. But still donít know what this other drain...drains.
Old 07-09-2018, 10:26 PM   #8
Trailer: Big Foot
TX
Zach,
On my Big Foot 25 there is a similar hose with valve ... but located under the dinette seat & plumbed in close to the water pump ... it is used to suck RV antifreeze into the system for winterizing ... my trailer manual does not mention this fixture or the winterizing procedure ... but you close a valve near the pump, open this one, put the hose into your jug of antifreeze, and run the pump ... while opening the various trailer spigots one at a time until pink stuff flows out.
I know not much help without pics or a diagram ...
But perhaps this is the purpose of the hose you describe.
Cheers,
CJ
dyno_76 is offline   Reply With Quote
Old 07-10-2018, 12:56 AM   #9
Borrego Dave's Avatar
No telling what a PO has done. You say it drains water with the pump. It may have been installed for de winterizing the system. Open the valve and check what's happening in your fresh tank level. Bottom line, some tank is going to loose fluid .
Old 07-10-2018, 01:05 AM   #10
Attachment 121737My Escape has a "low-point drain". It was discontinued when Thetford changed their toilet in such a way that the "low-point drain" didn't work any more.
It's on the far left, next to the fresh water tank. When opened it would drain all the water from the lines.
Maybe that's what it is.
Old 07-10-2018, 12:20 PM   #11
ZachO's Avatar
Montana
Alright, thanks everyone.
You never know, but I don't think this was an add-on. Seems original and nothing much had been modified on this trailer before I bought it.
I think the best bet is something to do with winterizing.
bigfoot
Water system question for 1991 Scamp LurkerDan Problem Solving | Owners Helping Owners 11 10-17-2014 01:12 AM
U-haul VT-16 Water system Matt in SV Plumbing | Systems and Fixtures 6 05-17-2010 08:17 AM
13' Scamp Water system diagram Wilder Plumbing | Systems and Fixtures 4 08-26-2009 07:52 PM
Losing prime in water system Paula D. Plumbing | Systems and Fixtures 19 06-07-2006 12:58 PM
Water system jefh Care and Feeding of Molded Fiberglass Trailers 6 01-17-2006 02:27 PM
