Bike Rack on 13' Scamp - Fiberglass RV
Old 03-31-2013, 03:32 PM   #1
Trailer: 13' Scamp
I need to attach a 2-bike rack on to my Scamp 2010. I can't use my usual rack that attaches to my 07 Forrester, not enough room between trailer and vehicle. I don't have a trailer hitch on the back of my scamp.
Thanks
Susan A is offline   Reply With Quote
Old 03-31-2013, 04:10 PM   #2
There have been previous discussions about bike racks, with all kinds of opinions. You may be able to find them by doing a search. I've built several bike racks on trailers but it's a topic I won't get involved in anymore. Gather info, go with what you think is best for you.
Old 03-31-2013, 04:14 PM   #3
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
If you do a search, use the google search at the bottom, the regular search is pretty worthless.
Whether or not you have a receiver hitch is a big start.
Old 03-31-2013, 04:16 PM   #4
Have you considered putting the bikes inside the trailer (less chance of theft and no road rash!)?
Old 03-31-2013, 04:18 PM   #5
IllAnnoy
Plenty of room for my Escape or my Ranger...
Old 03-31-2013, 09:29 PM   #6
chse's Avatar
Trailer: 13' Scamp
You can buy an aftermarket hitch receiver at amazon ("Scamp Hitch Receiver") if you want to mount them on the back of the trailer.
chse is offline   Reply With Quote
Old 03-31-2013, 09:47 PM   #7
Jared J's Avatar
Kansas
Pretty decent price. I'm using a different bumper, and I want to pull a trailer with it, so I'm building my own. If I wasn't, I would do that. I only know of two scamps that can (legally) pull a trailer, so it's a pretty moot point.
Old 04-01-2013, 07:08 PM   #8
Noah, from Orbital is a commercial vendor here at FiberglassRV: Our new webstore is open
Old 04-05-2013, 06:20 PM   #9
Trailer: 1980 Boler Deluxe
Where did you get your bike rack or did you have it made?
ccaffrey is offline   Reply With Quote
Old 04-08-2013, 08:02 PM   #10
Trailer: 2008 16 ft Scamp
We had the hitch put on the back of the Scamp when we ordered ours, tried bikes on it once and had so much extra sway that we said never again.
Floyd, that is a cool bike rack! It looks perfect!
RachelW is offline   Reply With Quote
Old 04-08-2013, 10:04 PM   #11
IllAnnoy
I made it from the scrap pile in my shop, the sides are the legs from a very old box fan, the crossmembers are pieces from a discarded bed frame and the racks are off the shelf rails designed for roof rack applications. They were attached in opposite directions to conserve space and mounted high enough to allow the inside bike to follow the contour of the Scamp. This rack has served us well for 9years now.
The racks used were of a similar design of the one pictured below...
Old 04-08-2013, 10:09 PM   #12
IllAnnoy
Thank you for the kind compliment!
Old 09-22-2013, 07:45 PM   #13
Name: Sue & Craig
Trailer: 13ft. Scamp
Red face Your Bike Rack
Hi Floyd, Saw pictures of your bike rack on the front of your Scamp, did you buy this or did you build it especially for the Scamp. It is just what we have been looking for. Thanks for sharing your info. Sue
Gnarly Sue is offline   Reply With Quote
Old 05-17-2014, 09:15 AM   #14
Trailer: 13' Scamp
Floyd! That is awesome. You should sell those.
beckimeadows is offline   Reply With Quote
Old 05-17-2014, 10:26 AM   #15
Possible, But Not Ideal
We also had a factory receiver installed. RachelW is correct - the extra weight aft does contribute to sway. I found it occasionally noticeable but not excessive, and we mitigated the problem by putting all of our heavier gear forward inside the trailer.
Another issue with the rear-mounted bike racks you should be aware of is bouncing. A trailer will bounce a lot more than a car, and the effect is magnified at the rear. That puts a lot of peak stresses on the rack, receiver, and the frame of the trailer (which is not known for being heavy duty!). It also means the bikes will bang into each other. Ours are inexpensive, lightweight bikes, and I have learned where to put padding. If you plan to spend much time on unpaved roads, this might be a deal-breaker.
In short, a rear bike rack is possible, but definitely not ideal.
Floyd's rig is clever and good for stability, but could overload the tongue for some TVs (such as the OP's Subie). Donna's suggestion is ideal for aerodynamics, security, and towing stability (and inexpensive, too), but I like being able to use the interior of the trailer en route. A roof rack system on the TV is another option - stable and secure, but bad for aerodynamics, pricey, and a pain to load/unload.
Lots of choices, none perfect, I'm afraid.
Old 05-17-2014, 11:23 AM   #16
Factory vs Aftermarket?
I ordered a hitch receiver kit from Scamp and had it installed per the factory specs (which included welding in an additional frame cross-member). At the time I didn't know about the Orbital bolt-on unit mentioned in earlier posts.
The factory kit was cheaper than than the aftermarket unit (even with shipping factored in), but because I had to pay a welder to install it, it came out a bit more expensive.
I don't know much about metalwork, so I wonder if some of the experts out there could comment on the relative strength of welded vs. bolt-on. Which would you recommend?
Bike Rack Greg Janke Modifications, Alterations and Updates 17 08-04-2012 10:47 AM
Bike rack russelld Problem Solving | Owners Helping Owners 18 02-23-2012 07:19 PM
1st Mod on 96 Scamp ( bike rack) Tim Wood Modifications, Alterations and Updates 9 06-23-2011 01:32 PM
Bike Rack on Scamp 13' barryra Modifications, Alterations and Updates 2 07-19-2010 12:42 PM
Bike Rack kathy chamblin Problem Solving | Owners Helping Owners 5 08-18-2007 09:41 AM
