Biker bunk mounting pics? - Fiberglass RV
Old 09-08-2010, 12:15 PM   #1
Trailer: 74 Boler
Boler bunk mounting pics?
Does anyone have a pic of how the bunk mounts to the wall in the early boler? Mine looks like it didn't come with one from the factory and I picked a used one and it seems like the support poles are too long. If I attach the hinges to the wall just under the window the front of the bed is an inch a bit higher at the pole end than the window end. Do the hinges go beside the window? Any help would be great, I'm trying to get the old girl ready for the first camping trip with two kids
Thanks!
Brian Tin is offline   Reply With Quote
Old 09-08-2010, 03:06 PM   #2
Raya's Avatar
Hi Brian,
The way the Boler 13 bunk hinges work is they raise the bunk cushion as you tilt it up. That happens because the hinges are sort of step-shaped. The step part mounts to a horizontal, wooden "shelf" that should be fiberglassed to the front wall of your Boler, under the front window. Here is how a 1974 looks, raised. You can just see the hinges at the back:
Name:	bunk hinge close.JPG
And a photo from a cushion (not mine) that shows the hinge closer up. There are three screws that go into the wooden "shelf" and three in the bunk bottom:
Name:   bunk hinge.jpg
The bottom end of the posts fit into these brackets:
Name:	bunk post bracket.jpg
And the top extends up over the bunk flat:
It's hard to see, but there is a little loop welded onto the side of the post, which catches a screw that projects from the bottom of the bunk piece, and that's what holds the post onto the top bunk:
Raya
Old 09-08-2010, 03:22 PM   #3
Trailer: 74 Boler
That's great, thanks!
Mine doesn't have the shelf piece so I guess I'll have to attach something like that.
Scamp front seatback/upper bunk mounting Bill White Problem Solving | Owners Helping Owners 5 11-14-2009 04:47 PM
Re-Mounting my awning Ed Harris Problem Solving | Owners Helping Owners 3 07-23-2007 01:03 PM
Battery Mounting J Martin Problem Solving | Owners Helping Owners 1 07-03-2007 05:10 PM
Mounting my generator??? Bob Maddox Problem Solving | Owners Helping Owners 5 06-19-2006 07:24 AM
The Biker and The Bridge Rick Jokes, Stories & Tall Tales 3 03-09-2006 12:11 AM
» Trailer Showcase
Yoda
dlux
SCAMP
lables
