Black dots on white silicon - Fiberglass RV
Old 12-01-2014, 01:19 PM   #1
We have a Scamp 13'. Just above the aluminum "beltline" is a bead of white silicon. The white silicon is now dotted with black dots, which we have been unable to remove. Take a look at the attached picture. Can anyone help?
Martin B. is offline   Reply With Quote
Old 12-01-2014, 01:28 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Mould????
Old 12-01-2014, 01:38 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
Definitely mold growing. Nothing beats this stuff: Wet & Forget | The Ultimate Mold & Mildew Remover & Shower Cleaner.
I know for sure, living in Oregon..........
Charlie Y
Charlie Y
tractors1 is online now   Reply With Quote
Old 12-01-2014, 03:42 PM   #4
IllAnnoy
Take it off and replace it with a "kitchen and bath" type silicone which is mildew and mold resistant.
Add Fels-Naptha to your wash water when washing your trailer.
Old 12-01-2014, 06:23 PM   #5
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Mold or mildew for sure. I suggest using a good clear caulk next time. Proflex or some other exterior caulk of your choice.
D Davis is offline   Reply With Quote
Old 12-01-2014, 06:38 PM   #6
I clean it off with common household bleach, applied with a toothbrush and it usually stays away. Wear eye and hand protection and rinse thoroughly.
Old 12-01-2014, 07:20 PM   #7
CampyTime's Avatar
Trailer: Scamp 13' Standard
This is definitely mold/mildew as I have it on my trailer (Scamp 13) in same spot. At somebody's suggestion here last year, I bought a jar of Concrobium power from Home Depot. Mixed as directed, minimizing foam, and then poured as directed into pump sprayer. Let sit on the belly band silicone for whatever it directed (2-3 hours maybe, I don't remember). Then rinsed it off.
I have done this same treatment twice now as my mold was quite bad. After the second treatment the white silicone over the belly band has been dramatically improved! Drove me nuts!
Just be sure you get the power that you mix in a bucket, not the spray as it doesn't work. The one I got was called "Concrobium Mold Stain Eraser."
It did not harm my trailer's FG/gelcoat either.
Old 12-01-2014, 07:22 PM   #8
CampyTime's Avatar
Oops, I read my directions and they aren't clear. After pouring into home type pump sprayer (one you'd use for spraying insecticide or what-not) I then pumped it full of pressure and sprayed on belly band. If you don't like that idea, you could spread it on with a crummy paintbrush, which I am sure I also did in order to maximize the amount of product sitting on the belly band.
Sorry for any confusion.
Old 12-01-2014, 08:52 PM   #9
Clear caulk doesn't stay clear for long. My suggestion is to soak an old white rag in bleach, lay it on the belly band and let it sit there for a few minutes. Rinse and move on to the next spot.
Old 12-02-2014, 12:31 PM   #10
Smile
Thanks everyone for the info. It took just one rainy winter here in Western Washington for our 2013 Scamp 13' to develop moldy caulk at the belly band. Will try some of the recommendations once we get back to non-freezing weather.
Dave Harris is offline   Reply With Quote
red and green dots? Cheri in MN General Chat 16 10-02-2012 08:49 PM
Silicon Muck, FG & Fresh Hands D Davis Problem Solving | Owners Helping Owners 2 03-23-2012 12:46 PM
Replacing a vent -- silicon? nebraskama Care and Feeding of Molded Fiberglass Trailers 20 02-08-2012 06:45 PM
Black or White Tongue Box? Lisa H. Care and Feeding of Molded Fiberglass Trailers 19 06-01-2009 10:34 AM
Putty Tape or Silicon for under the Awning Rail? Mike Montville Problem Solving | Owners Helping Owners 6 03-31-2008 02:40 PM
