Blowing fuses - Fiberglass RV
Old 01-10-2014, 12:14 AM   #1
Iowa
Blowing fuses
Everytime we connect the lights in our Scamp it blows the fuse in our car and we lose tail lights on it and the trailer. We still have turn signals and brake lights. If we unhook and replace the fuse it works again but the second we reconnect the trailer we blow the fuse. We bought the trailer new last April and this didn't happen until several months later. Any ideas?
DebbieDB is offline   Reply With Quote
Old 01-10-2014, 03:53 AM   #2
Trailer: Scamp Deluxe 16ft
Alabama
A wild guess is a short grounding out or too much of a load on circuit.. possibly if newer vehicle with the canbus wiring plus colder weather. I fried a vehicle power port outlet with a 12 volt fan/ heater.
I'm shooting in the dark on it. IE: wild guess.
Darrell in Al is offline   Reply With Quote
Old 01-10-2014, 07:01 AM   #3
Iowa
Thanks Darrell, I was thinking a short in the connector. I wondered if this was common. I find it odd that the brake lights and turn signals work but not the tail lights.
Old 01-10-2014, 07:48 AM   #4
Another rare occurrence, but I have had a tail light bulb short internally due to a broken filament. Another idea, wire problem in the plug if you have the 7 pin plug. Sounds like a short that you will have to locate, check bulbs and sockets, wiring anywhere you can see it. Shorts can sometimes be difficult to locate.
Old 01-10-2014, 09:00 AM   #5
Pretty much what Bob suggested but just a little more detail.
The side marker and taillights (running lights) are on the same but different circuit than the turn/brake lights. The Scamp wire color code is green for the running light wire. You have a short in your running light circuit. The most abuse is at the 7 pin plug , I would check this first, remove the green wire and reconnect the plug if it does not blow the fuse then it is a wiring or light bulb issue. Next remove the running and taillight covers and remove the bulbs and check for a short in the fixtures and bulbs then check the wiring with a meter. If there is still a short start tracing out the green wire and check for a shorted wire.
The Scamp website Owners Manual will give you the 7 pin wiring configuration and the wiring color code.
Eddie
Old 01-10-2014, 09:36 AM   #6
Raz
Raz's Avatar
From what you are saying the car and trailer worked fine at one point and now you have the problem. As Eddie suggests, this sounds like a fault in the trailer running light circuit, not the car. Since your trailer is less than a year old I would suggest you call Scamp. It seems they should cover it under warranty. If you had the car wired locally, I would take it there, but any auto technician should be able to troubleshoot the fault. If you choose to deal with it yourself you will need a multimeter. Good luck, Raz
Old 01-10-2014, 10:22 AM   #7
Lets see. Everything was fine for months and now you have a short somewhere in your trailer. Has anything been changed since you used the trailer ? Did you do anything that might have caused a wire to get pinched or a light socket to get damaged ? Did you change any lamps (light bulbs) ? Did anyone work on anything electrical. Those areas are where I would start looking. It's pretty easy to cause a short especially in the running lights if someone worked on or damaged them.
I had a similar problem and it was a bent connector in one of the running lights.
Old 01-10-2014, 12:23 PM   #8
When I had this issue it was the tail light converter added to the car to convert the tailight wiring of the car to the compatable wiring for the trailer. Get a test plug for the car wiring to isolate the issue from the car or the trailer.
etrailer.com - Products trailer tester
Old 01-10-2014, 06:32 PM   #9
Iowa
Thanks for all your replies! Will try the fixes you all listed.
Old 01-12-2014, 03:06 AM   #10
Alabama
Sorry if my response was flippant.. my phone has just updated and now it auto corrects and won't let me use smiley icons. I'll need to remember how to use the punctuate for the icons.
Blowing fuses Kevin K Electrical | Charging, Systems, Solar and Generators 13 07-06-2013 08:24 PM
blowing fuses, exterior lights not working! morbank Electrical | Charging, Systems, Solar and Generators 18 06-06-2013 09:56 PM
Blowing fuses and receptacle question.. Bluebamboo Electrical | Charging, Systems, Solar and Generators 19 05-29-2013 03:52 PM
Atwood furnace new on Trillium..won't kick on...fuses fine.... lloyd cicetti General Chat 15 04-12-2010 08:21 PM
The fastest fuses blower Legacy Posts General Chat 8 07-04-2003 02:36 PM
