Boler: advice on cutting a large serving window opening - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 03-24-2014, 12:05 AM   #1
Hi There,
New owner of 73 13' Boler. Looking to convert it to a coffee/ice cream trailer, and as such I want to make big serving window along the side of trailer where the sink and stove would normally be.
I'm looking for advice on:
-cutting such a large piece of the fiberglass, both on how to cut it and what to cut it with? (I have seen some posts about cutting smaller pieces or making small holes and some about filling holes in, but it doesn't sound like too many people are chopping big holes in their trailers!).
-whether I should consider some kind of supports to keep structural strength intact?
-when cutting this serving window, should I removed the ensolite along the cutting area, or can I cut through the fiberglass and ensolite at the sametime?
-is it a good plan to use the cut out fiberglass piece as the 'window' to be opened and closed for daily serving, or should I consider something else like wood?
-advice on what kind of hinges to use how to mount them?
Thanks for any advice/comments
Here is a photo of the side of the trailer, ideally I would like to get an opening between 6 to 7 feet long, and over three feet tall.
Gerry Taft is offline   Reply With Quote
Old 03-24-2014, 01:07 AM   #2
Borrego Dave's Avatar
Hi Gerry, I have made a few cuts on my SD 17 and used a multi tool....what a clean cut. I would suggest not trying to cut the inner covering with it thou. Have done a lot of fiberglass work on dune buggies but didn't have the multi tool then, dang. I have no clue to what you will have to do to support the roof and sidewalls making that big of an opening. I would think that that big of an opening will really weaken the shell. Possibly glassing in wooden gussets on each side of the window up to maybe 1/4 of the roof may do it. Someone did replace the factory supports in a 5'er kind of like I'm saying but I don't remember who it was. I'm sure someone else here with retro/roof experience will speak up. As far as a service door, mmmm, maybe find something from a scrap yard that could be retro fitted for your use. Fiberglass work isn't that hard, just kind of messy and it looks like your going to be painting the outside anyway. Well there's my pennies worth, good luck and give us some pics of what you end up doing.
Old 03-24-2014, 08:32 AM   #3
Trailer: 1976 Trillium 1300
Don't if you saw this one, may give you some ideas
The Happier Camper • "BARbra" the Portable Bar. And she's beautiful.
kootenaigirl is offline   Reply With Quote
Old 03-24-2014, 11:30 AM   #4
Thanks Borrego Dave and kootenaigril! I found this: http://www.fiberglassrv.com/forums/f...ics-45985.html
I don't want to go quite that far with the opening.
Old 03-24-2014, 12:05 PM   #5
Trailer: Class A Motorhome
I saw the Happier Camper ice cream stand at the Palm Springs vintage trailer show a couple of weeks ago, very, very neat.
I'd suggest that you have your new window "In Hand" before you start to cut. Even a 1" error in dimensions could be a disaster.
I would also suggest, because you are cutting out so much side support, that you back up your cut with at least 1" x 1" aluminum angle.
As far as cutting, I used to use a saber saw, but now I only use a oscillating multi-tool for cutting fiberglass. Much less mess, easier to guide, more accurate etc.
Good Luck.
Old 03-24-2014, 01:40 PM   #6
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I put access hatches in all four corners of my Trillium and will offer the following advice:
NUMBER ONE, regardless of the tool:
Each corner must be rounded. Otherwise you're going to get spreading cracks. Best approach is of course the simplest: Drill out each corner first. Doesn't have to be a huge hole, just round. Whatever framing you use will cover the holes.
-I used my smallest Porter Cable circular saw to make the cuts, where possible taping a guide onto the fiberglass, otherwise sighting the line.
-Certainly you'll have to reinforce the cutout to compensate for the loss of structural support. In my case the holes were smaller and the inset frame of the hatches I installed were sufficient for that purpose. In your case, I think you'll need such support both inside and out- perhaps 1' aluminum inside as Bob suggests, riveted or bolted through to L-shaped aluminum framing on the outside.
Old 07-06-2014, 09:18 PM   #7
Finally got a window and put it in today
Old 08-22-2020, 11:15 PM   #8
Trailer: Ventura Monarch
Smile Details on your experience please!
Hey Gary! I know it's been awhile since you installed a serving window in your Boler but I was hoping you were still on this forum and could go over how you did it? I will be installing one in my Ventura Monarch in the near future and would love to hear about your experience in more detail! Thanks
ambleandsip is offline   Reply With Quote
boler, vin
Single-serving Pie-Makers? Legacy Posts Camp Cooking, Food & Recipes 56 01-27-2012 01:59 PM
Cutting into icebox opening karen lm Problem Solving | Owners Helping Owners 2 09-17-2009 02:46 PM
cutting table bench side opening johnsoba Problem Solving | Owners Helping Owners 4 04-20-2009 08:50 PM
Cutting into icebox opening Gail S. Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
