Boler Bolts - Fiberglass RV
Old 01-31-2010, 03:40 PM   #1
While in the midst of a full interior reno,I'm looking at the number of bolts that hold the body onto the frame.Up front,I see only a couple but some empty holes.At the back,there appears to be lots.
Questions:how many are there supposed to be?
What would I be screwing into,from inside the Boler?Is there a buffer between the frame and the body?Is there any specific bolt/screw that anyone has replaced/used in this circumstance?
Thanks.
Rick Harmer is offline   Reply With Quote
Old 01-31-2010, 05:07 PM   #2
Robert Johans's Avatar
Trailer: Nest Caravans
Thanks.
You can do a search on this forum for "Boler frame off" or something similar.
See if this doesn't get you going...
http://www.fiberglassrv.com/board/in...howtopic=23260
Old 02-01-2010, 10:31 AM   #3
Raya's Avatar
Hi Rick,
I've seen a couple of different attachment methods. (And there may be more.) On my 1974 (and others of similar vintage), there are screws that go into the frame. So, just through the fiberglass, through the floor core, and into the top of the frame. They dead end inside the frame.
On a late 70s Boler, I saw that it had the same as described above, and then also some (factory) right angle tabs welded to the frame, and then some bolts going into those (through the fiberglass floor, through the floor core, through the tab, then, IIRC, a nut).
Amazingly, although I've seen a number of these where they are either missing or will just spin, I haven't heard of a shell blowing off on the road. Must be friction.
I think the late 70s method is a nice one, but on the other hand, when I was thinking of using bolts through the frame to re-new mine, several people pointed out that it is better, structurally, not to do that (and, their reasoning was sound). Given how many are loose or broken on so many Bolers, and how few seem to have given way, I decided I would be doing just fine by using the same method with new, slightly oversized fasteners of the same style (screws into the frame).
I have heard of people retrofitting with large U-shackles (like on trailer frames), but I don't think one has to do that (it's good though, of course).
If you are getting any core crushing where the screws go through, you could overdrill and fill with thickened epoxy to create an annulus. OTOH, if all is dry and fine, it's probably okay as is, since it's not an area where water will sit.
I started a thread on this about 9-10 months ago, if you wanted to search for it, although the upshot is summarized above.
Raya
boler
Trillium Body Mounting Bolts Larry C Hanson Problem Solving | Owners Helping Owners 3 09-03-2015 10:54 AM
Bolts and Walls Rob L Problem Solving | Owners Helping Owners 11 11-18-2009 04:32 PM
Floor to frame bolts Tom U Problem Solving | Owners Helping Owners 0 05-10-2009 02:02 PM
bolts breaking April Wilcox Towing, Hitching, Axles and Running Gear 11 11-18-2008 03:12 PM
Nuts - Bolts % Other HDW Darwin Maring Problem Solving | Owners Helping Owners 1 05-09-2007 06:03 PM
