Boler Cabinet Door Catch / Latch Replacement - Fiberglass RV
Old 06-07-2010, 08:18 PM   #1
Hello,
Does anybody know where to get replacement (same look/style as original) cabinet door catches? The one for my closet got brittle and snapped in the winter when I closed the door.
If there are no no close OEM replacements, what have you guys done for new catches?
Thanks in advance.
Mike
Mike Roho is offline   Reply With Quote
Old 06-07-2010, 11:17 PM   #2
Flygal's Avatar
well if no one else chimes in...if you absolutly cannot find these in the color you want I live near a "restore" place (recycled hardware ect) and with a photo could look for you...
Flygal is offline   Reply With Quote
Old 06-08-2010, 02:08 AM   #3
Raya's Avatar
I don't know what yours look like, but I've seen two different types of catches on Boler 13's:
1) You pinch a square on both ends simultaneously
2) There is a single button that you press with your thumb
Both are available at Vintage Trailer supply on this page:
http://www.vintagetrailersupply.com/Cabine...rdware_s/83.htm
#1 "Pinch catch" looks like an exact match, while #2 "Brass push button cabinet latch" has a slight convex hump and a linear pattern, whereas the originals I've seen have a slight concave hump and a pebble pattern - but they are pretty close.
I've seen other varieties of #2 at other RV suppliers, with different embossed patterns - but always with the convex hump. However, since the closet is a "solo" handle, away from the others, it might not be that obvious (or perhaps you have an even less obvious location and can switch a couple of catches).
boler
Cabinet Thumb Latch needed x 2 Kurt in BC Classified Archives 5 02-22-2009 10:45 PM
Wanted:1 original cabinet latch for Trillium 4500 Joe Loiacono Classified Archives 14 02-16-2009 10:57 PM
Boler Door Latch Doug Mager Classified Archives 0 08-08-2008 10:05 AM
Find replacement Scamp door latch/lock Faith Problem Solving | Owners Helping Owners 2 11-02-2006 06:45 AM
Door handle and latch replacement for a '75 Boler KenReiss Problem Solving | Owners Helping Owners 9 07-15-2006 11:51 AM
