Boler Couch - anyone have a photo (Front Gaucho) - Page 3 - Fiberglass RV
Old 04-26-2006, 04:10 PM   #29
Trailer: 1970 Boler
ps - my email is redr2@telus.net....may be easier through email..
- Kurt
Kurt in BC is offline   Reply With Quote
Old 04-27-2006, 03:42 PM   #30
Trailer: 1970 Boler
anyone?
Old 04-29-2006, 08:35 AM   #31
james kent's Avatar
Trailer: Boler 1984
Hi Kirt!
Take this for what it's worth. I went and took some pics this AM.My Boler is a "84 But very similar.
Here is the seatback vertical with the filler behind.
Old 04-29-2006, 08:38 AM   #32
james kent's Avatar
Trailer: Boler 1984
Here is the bunk raised.The brackets are merely shower rod holders and 1" aluminum tube.
Old 04-29-2006, 08:45 AM   #33
james kent's Avatar
Trailer: Boler 1984
Here's a shot from underneath showing the support bar. It's just a piece of 3/4 plywood 2" wide and 31" long, fiberglassed into place and covered with the same material as the walls. You will notice that some of the models in the late 80's had a cloth not ensolite.
Old 04-29-2006, 08:49 AM   #34
james kent's Avatar
Trailer: Boler 1984
This is the filler piece. It's 63x6x4".cut the curv to fit.
Old 04-29-2006, 08:52 AM   #35
james kent's Avatar
Trailer: Boler 1984
This is looking down on the support. The seak back has been attached using butt hinges. Piano or other may look better.
Old 04-29-2006, 09:01 AM   #36
james kent's Avatar
Trailer: Boler 1984
I've unzipped the cushion. The plywood back has been made in 3 pieces. This is so it will fit the curve of the wall when vertical. The center piece is 61x22". the ends are cut to fit leaving about a 2" gap at the walls.These pieces are also butt hinged. THe support bar was installed 4" down from the top edge of the window rubber. When the seat back is raised it is almost flush with the window.
Old 04-29-2006, 01:20 PM   #37
Trailer: 1970 Boler
James
You are truly a life saver - that was exactly what I needed. I will post pics of mine when I'm finished!! Thank you!!
Old 04-29-2006, 02:17 PM   #38
james kent's Avatar
Trailer: Boler 1984
Glad to help. I know there are better ones out there but it'll give you the basics. The rest is cut-n-fit.
Waiting to see the finished thing.
Jim
Old 05-01-2006, 10:22 PM   #39
Trailer: 1970 Boler
Finally finished the thing. It was a hell of a lot of work. Dtill have to buy the foam and the fabric to cover it but the hardest part is done.
Thanks for the advice everyone!
Old 06-06-2006, 12:57 PM   #40
bill&sandra's Avatar
Name: Bill & Sandra Hanna
Trailer: 19' 2011 Escape
Send a message via Yahoo to bill&sandra
I have a 1970 Boler and the last guy ripped out the couch and installed more counter top space. Works great except now we have a little girl and need the extra bed. Just wondering if someone could post pics of their couch without the cushions so I can figure out how to build mine. Thanks everyone!!
- Kurt
thanks, Kurt
for the site and the pics of your bunk assembly. makes perfect sense. wiill see if we can do that in our little scamp. now i see that that long thin upholstered piece is for--to sit on top of the hings so don't pinch at night! cool.
bill&sandra is offline   Reply With Quote
Old 06-06-2006, 03:20 PM   #41
On a Boler, the long thin banana piece is used to keep the top bunk at a slant when it`s down and to shorten the depth of the bottom cushion from your knees to your butt when you`re sitting on it and is wider for use for sleeping when the top bunk is up.... and the slant, so it`s more comfortable to lean back on as opposed to being 90 degrees to the cushion when sitting.....Benny
Old 06-06-2006, 09:00 PM   #42
colin k's Avatar
Trailer: 73 Boler
I use the banana as a lumbar support . So its out 90% of the time.
colin k is offline   Reply With Quote
boler
Front page photo BOBSMITH General Chat 5 06-30-2010 04:06 PM
Front Dinette Construction/Couch Removal Question Karen B. Problem Solving | Owners Helping Owners 2 06-13-2009 09:03 PM
Front page photo Rusty01 General Chat 1 05-06-2009 10:57 PM
the bunk over couch in Boler 17 Peggy Problem Solving | Owners Helping Owners 1 05-06-2008 12:23 PM
Rebuilidng Front Couch to Dinette Jackie Modifications, Alterations and Updates 5 04-12-2006 12:12 AM
