Boler door bolts - Page 2 - Fiberglass RV
Old 06-24-2013, 10:57 PM   #15
Brian B-P's Avatar
Originally Posted by Donna D. View Post
Humm, is there enough of the brass ball visible to take a hack saw and carefully saw through one of them?
I like your thinking... but it might be difficult to keep the ball from turning while it is being cut.
Old 06-25-2013, 05:04 AM   #16
Roy in TO's Avatar
If one bolt is broken, undo the other one and push it through the hinge. You should be able to lift the door up enough to get off the balls.
Old 06-25-2013, 09:37 PM   #17
jlbails's Avatar
Trailer: Boler 1977
A strong friend succeeded in lifting the door off the brass balls by leveraging a screwdriver between the hinges.
Somehow the door latch caught the bottom of the face plate in transit. I swear I don't remember hitting anything! Doesn't help that the door is 1/2 inch lower, and allows the latch to drop down. Taller brass balls are in order to lift the door to the correct height. Won't help the sag, but at least the latch will be in proper position.
Once we got the door open, he installed a 12 volt plug, a nice update to the ol' girl.
Thanks for all your suggestions and support!
jlbails is offline   Reply With Quote
Old 06-25-2013, 10:16 PM   #18
Jamie you can older this Door Hing repair kit from Scamp for $5 - you will need two. To bad it didnt happen on the way to the meet I could have given you the set sitting in my trailer waiting to be installed.
Old 06-26-2013, 04:06 PM   #19
RLP
Trailer: 72 Boler
I would not suggest getting larger brass balls (I know, that just doesn't sound right) but instead, get the same size as original because of the pocket they sit in. I also used 1/4" SS bolts with Nylock nuts. This might be a good time to refit the door to it's proper position. Bolers were/are notorious for door sag.
I did this on my 13' Boler by removing the hinges from the door, filled the hinge bolt holes with epoxy and re-drilled new holes at the correct location so the door sits in the proper position. An added bonus after the mod was that the latch bolt now lines up with the strike plate. I also replaced the door weatherstrip with a newer style to complete the modification.
RLP is offline   Reply With Quote
boler
condensation on bolts john warren Problem Solving | Owners Helping Owners 7 04-09-2012 12:45 PM
Window slide bolts door of Compact junior Kent I Problem Solving | Owners Helping Owners 4 09-28-2011 08:19 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
need new door mount bolts thenoob Problem Solving | Owners Helping Owners 3 02-07-2011 03:11 PM
Boler Bolts Rick Harmer Problem Solving | Owners Helping Owners 2 02-01-2010 10:31 AM
