Boler Door Hinges - Fiberglass RV
Old 04-08-2006, 01:49 PM   #1
Barbara Gardin's Avatar
This was discussed a long time ago before hacking. We removed the door hinges and didn't note whether no.1 or no.2 was on the top . Does anyone remember?
Barbara Gardin is offline   Reply With Quote
Old 04-08-2006, 08:24 PM   #2
Brian B-P's Avatar
I don't remember, but if you have the hinges and want to know where they go you can tell by looking at them. The hinges are different only because they are designed to follow the curve of the trailer body, while keeping the pivot axes (bolts) vertical.
With the hinge assembed and held in place against the trailer, the right hinge for that location will be the one in which the bolt is vertical; the bolts of the two hinges will line up with each other when both are installed.
I'll try to remember to check my Boler tomorrow - it is a later year and larger size, but my guess is that the hinges are the same.
Old 04-08-2006, 10:47 PM   #3
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
No.1 Top: No.2 Bottom
Con is offline   Reply With Quote
Old 04-09-2006, 01:53 PM   #4
Lizbeth's Avatar
They're numbered? I bought new ones from Scamp and I don't remember there being numbers on them. I will have to ask hubby if he remembers numbers.....Oh dear, more confusion.....
Old 04-09-2006, 05:34 PM   #5
Brian B-P's Avatar
Now here we see why I would rather look at angle of the hinges than go by the numbers: while Con has #1 on the top, my 1979 B1700 has #1 on the bottom (and #2 in the top position). Mine are in the correct positions, but I'm sure Con's are as well. It may have varied by factory, by year, by batch of hinges, or by the mood of some installer, for all we know.
Update on Edit:
Even with Con's correction (next post, below), I would look at the hinges to make sure the position made sense.
Old 04-09-2006, 05:46 PM   #6
Con
Sorry everyone, I goofed. My memory is not what it used to be so I went and looked Brian is right. No. 2 on top.
Old 04-10-2006, 07:50 AM   #7
Thanks all. The hinges are re-installed 2 on the top 1 on the bottom. The door fits much better now.
boler
13 ft boler door hinges steve J Problem Solving | Owners Helping Owners 1 09-11-2009 09:01 PM
boler door hinges Brandon G Problem Solving | Owners Helping Owners 3 07-23-2009 10:01 AM
Door Hinges Phillip Modifications, Alterations and Updates 8 06-23-2009 02:34 PM
Looking for some Door Hinges.... mcnick Problem Solving | Owners Helping Owners 23 06-18-2007 06:52 PM
Looking for some Door Hinges.... mcnick General Chat 0 01-01-1970 12:00 AM
