Boler door reshaping - Page 2 - Fiberglass RV
Old 12-08-2014, 07:38 PM   #15
Steve_74's Avatar
Some pictures of my door and frame
Sent from my SGH-I747M using Fiberglass RV mobile app
Steve_74 is offline   Reply With Quote
Old 12-08-2014, 07:40 PM   #16
Steve_74's Avatar
I need to do more work to the hinges a little build up. There is about a inch of weather stripping along the top that the PO had installed
Old 12-08-2014, 07:46 PM   #17
Trailer: 1978 Boler 13'
Hi Steve.. I joined in your thread thinking we had similar issues.. I hope we can both get our doors straightened out!
Thanks Ian! I am going to rebuild my hinges. This I think is something that I can manage.
lorenleigh is offline   Reply With Quote
Old 12-08-2014, 07:54 PM   #18
Since you are in Canada, and shipping (customs) can be a problem when contacting Scamp... see if Paul has what you need for your hinges: Fibreglass RV Parts, Repairs, and Service by Paul Neumeister
Old 12-09-2014, 05:48 AM   #19
Ian G.'s Avatar
Steve, it is hard to tell but it does look like your hinges also need a rebuild. The other thing I would check on yours is make sure the screws that secure the wooden body supports by the door on the inside are tight. I would be investigaing why the trim piece has bowed out like it is, might be just the glue has failed and it has fallen off, but it the body has sagged a little it may also cause this.
Old 12-09-2014, 07:46 AM   #20
Steve_74's Avatar
I pulled the trim off to see what the support was made of. I put new brass balls in but I think I am going to build the hinges up with some liquid metal. The support seems tight but maybe I should take it off and check a little closer and put new screws in.
Old 08-21-2015, 05:51 PM   #21
Johnny M's Avatar
Deep South
Originally Posted by Ian G. View Post
Although many have recurved their door to make it fit better I still insist that the shape of the door remains constant and the actual body on the 13' Boler has sagged some. The sagging body will result in slightly more curve to the profile where the hinges mount and the result is the door gaps. Actually a very small change in the curvature and or misalignment of the door hinges can cause a considerable gap. Try adjusting the door and hinge position first, the upper hinge often moves down and towards the back of the trailer so adjusting the door hinges so the door sits square in the opening and tighter to the top of the frame.
While we did have a slight roof sag due to the a/c unit on top, the body near the door did not appear to have distortion and the metal was still in tact to the inside right of the door as well as the left side to the closet. We had a slight gap above and below the door which the PO had attempted to fix with scamp hinges. Due to a lot of flexing in the door top to bottom and seeing another post here about a door rebuild I pulled our door apart to find a lot of mushy pulp of what was left of the original wood that helped the fiberglass door hold its curved shape. Besides the mushy wood the door was mostly hollowed out with the only intact wood being above the window and some of that even had rot in it. I ending up making a metal frame carefully hand bent to the curve of the door jam and then using a 2 part epoxy to bond the outer door to the frame. The metal should last much longer than the wood and hold the doors shape better and stronger. Now I just got to get my hinges in the right spot to get the door to open fully, right now the door hits the belly band before it is full open, I believe the hinges on the body need to move closer towards the door opening to allow for more swing out, which will require I re-drill the holes on the door as well.
boler
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 11:39 AM
Wanted: Cushions, closet door, door window scamp53 Parts: Buy | Sell | Trade 0 06-25-2012 06:41 AM
Wanted: Boler Hinges - Looking for a pair of Boler Entry Door Hinges idiotsniff Parts: Buy | Sell | Trade 6 01-13-2012 10:02 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door Risers.. Door Props.. Hatch Holder upers?? earl squirrel Problem Solving | Owners Helping Owners 2 05-23-2011 05:07 PM
