Boler Door Seal - Fiberglass RV
Old 03-27-2011, 10:19 PM   #1
RLP
Trailer: 72 Boler
Boler Door Seal
I have a 1972 Boler and I made a few adjustments to get the door lined up (still off a bit). I removed the old seal which was a sticky back 1/4" x 1" black foam strip. Now I need to install a new door seal.
What was originally on these Bolers and what is a suitable replacement seal? When closed my door does not sit an equal distance from the body all around - varies from almost touching (below the latch) to 3/8 inch away at one top corner (hinge side).
Thanks in advance.
RLP is offline   Reply With Quote
Old 03-28-2011, 11:29 AM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I think the Scamp parts on line can help.
Old 03-28-2011, 07:03 PM   #3
CliveAlive's Avatar
Trailer: Boler American (#3104)
Thanks in advance.
I don't know what was original but what I used was the side-door seal from a mini-van at the PnP. I searched around for one that was big enough to handle those very same variances.
Good luck!
Old 03-28-2011, 07:06 PM   #4
I use heavy density foam tape weatherstrip - closed cell (1/2 thick by 3/4 wide) bought two packages at Lowes... it's 10 feet long. Peel and stick, cheap enough to replace as needed.
Says it's minimal compression for tight seal between smooth surfaces.
Old 04-01-2011, 07:14 AM   #5
Borden's Avatar
Name: Borden and Carole
Living in Canada the cold weather makes the weatherstrip freeze to frame and door. Removing striping now and adding new hinge bolds; will fill holes with epoxy putty then will re-drill and align door to original placement. Still to cold to do the putty part but hope will be warm enough soon. Getting tired of the snow. Hope to fix draft with proper alignment as original seal looks fine.
Our postage stamp in heaven.
boler
u-haul door seal Terry G. Problem Solving | Owners Helping Owners 13 06-07-2016 10:04 AM
Boler door seal RogerH Problem Solving | Owners Helping Owners 3 04-02-2012 06:33 PM
Scamp Door Seal Parker Buckley Problem Solving | Owners Helping Owners 16 10-11-2011 09:55 AM
Burro Door Seal Legacy Posts Problem Solving | Owners Helping Owners 8 02-12-2003 01:39 AM
» Trailer Showcase
TBA
Ian Hepher
Bluey
72Bluey
