Originally Posted by rosey45385
when I purchased my 72 boler the door needed the correct hinges to be installed on the door. took it to a friend who has a body shop. A p.o.had installed a solid window and did a bad job the door was cracked and the window was broke it was a real odd slze I coild not find any information on that size of window .So my friend repaired the door and filled in the area of the window. I have a 6 x 18 inch window that came out of another boler. I would like to know the length of screw and if they go into wood strip on the inside? what size wood strips. have not seen a good picture of this window on the inside of a boler door.
Hi: rosey45385... The door window on most bolers was a Hehr window and pop riveted to the
fiberglass . It was also used on a lot of Airstreams. Our boler had one as the kitchen vent. I rebuilt it and replaced the rivets with S/S screws and wood strips as clamps inside. All gaskets were avail. from Vintage Trailer Supply.
