Boler Fantastic Vent Install - Fiberglass RV
Old 06-18-2016, 09:41 PM   #1
Markz's Avatar
So I finally got the wiring through the rat fur and dropped in the new fantastic vent in my Boler.
Unfortunately I believe it is too low as the turn nob hits me in the head.
I bought the Fan from Vintage Camper Supply.
I am wondering what others have done to address this problem.
I do not want the tines of the camper to be disturbed too much either.
Does anyone know if Fantastic vent sells a shorter turn knob?
How difficult is it to add a spacer on the roof?
Are their threads on this same install in a Boler Roof.
Thank you.
Markz is offline   Reply With Quote
Old 06-19-2016, 03:55 AM   #2
Borrego Dave's Avatar
Thank you.
A few members have added a spacer on the roof. A PVC rectangle tubing seems to be what most have used but I think it was more for a roof thickness issue than low knobs. Sealing it would be the same as installing the vent although I don't remember if they used butyl at the corner joints. Someone who did a spacer will be along soon with more info.
Old 06-19-2016, 08:15 AM   #3
Markz's Avatar
Thank you. I'm very curious about the different spacer options.
Old 06-19-2016, 09:11 AM   #4
Keaner's Avatar
Trailer: 1973 13' Boler
My fan had a shroud that came with it. Did you install that without modifying it? I cut mine down about 4in and it sits flush now. A pic would help.
Keaner is offline   Reply With Quote
Old 06-19-2016, 09:16 AM   #5
Alf S.'s Avatar
Hi: Markz... I installed our MaxxFan using two 3/4 ply spacers. One through the roof and one from the inside. Just enough to recess the knobs and I was able to stretch the Ensolite over them.
Old 06-19-2016, 12:24 PM   #6
Clayton's Avatar
Trailer: 1975 Trillium
Here is the link to my install on my MaxxFan.
http://www.fiberglassrv.com/forums/f...all-71689.html
Clayton is offline   Reply With Quote
Old 06-19-2016, 08:38 PM   #7
Markz's Avatar
I purchased some PVC lumber from Home Depot and will make a frame to raise it 3/4". I've seen some go to 1 1/2" higher but I fear the original roof profile will be too disturbed.
I'll post some pictures when it is done.
Thank you.
Old 06-19-2016, 08:46 PM   #8
Markz's Avatar
That looks Fantastic.
Old 06-20-2016, 04:47 AM   #9
Raz
Raz's Avatar
Thank you.
There is seldom an issue that hasn't been discussed here before. To use the search feature click on Search at the top of the page and use the Google search blank.
search results
Old 06-20-2016, 10:14 AM   #10
Having trouble finding what is listed above as rectangular pvc tubing and pvc lumber. Could someone post a link to them please?
I made a spacer out of plywood that I then sprayed with leak seal. I put on top of the trailer and it worked well. However, it looks like it is starting to peel off already so who knows how long it will be till it starts to leak.
TimR is offline   Reply With Quote
Old 06-20-2016, 09:20 PM   #11
Markz's Avatar
I purchased white 1x3x12 PVC board from Home Depot. I think I can glue the frame together with PVC cement. I will use a table saw to cut it down to 1 1/2" strips to make the frame.
Old 06-21-2016, 06:15 AM   #12
Cool thanks!! Does it have a solid core?
Old 06-23-2016, 11:12 PM   #13
Markz's Avatar
Correction it is 3/4"x 4x12 and yes it is solid pvc
Old 08-03-2017, 12:19 AM   #14
Markz's Avatar
Done. Thank you!
Old 08-11-2017, 10:10 PM   #15
Markz's Avatar
I did also cut down the threading on the screw knob by 5/8" and reattached with a shorter screw. That gives me just enough clearance to not hit my head on it but will brush through my hair. Luckily it's not curly.
boler
Trouble getting wire through Rat Fur for Fantastic Vent install Markz Problem Solving | Owners Helping Owners 11 06-19-2016 08:44 PM
Maxxair vent vs Fantastic vent? MinnesotaJill Modifications, Alterations and Updates 33 07-26-2014 08:54 PM
Fantastic Vent Still Fantastic Thomas G. General Chat 1 06-27-2013 02:59 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
» Trailer Showcase
Believe
Donna E
Scamp
EmilyMcG
