Boler floor - Fiberglass RV
Old 06-21-2007, 04:31 PM   #1
Trailer: 17 ft Boler 1700 1978
ok my boler's floor is a little soft in the center my black tank is under it what would be the best way to fix this .
jj giger is offline   Reply With Quote
Old 06-21-2007, 07:13 PM   #2
Brian B-P's Avatar
Your black tank is under it, jj? Interesting... my black tank is on top of the floor, with the fresh and grey tanks under it. It might matter which tank is which, from the perspective of effort to possibly remove the tank, depending on the chosen method of repair.
Which floor plan is this: the side gaucho (B1700SGH), rear gaucho (B1700RGH), or another layout (with Bolers, you never know...)
There are some B1700's with fiberglass floors, although most (like mine) seem to be just plywood. Is there a fiberglass layer on top of or under the plywood, jj? Or is is just fiberglass?
And while I'm asking questions: what's on top of the floor - the finished surface? Mine is the original sheet vinyl flooring, so if I removed part for a floor repair I would have some interesting patching to do.
Old 06-21-2007, 08:57 PM   #3
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
Mine was wood/lino. Now it's wood and laminate.
The laminate cost about $30, took about 2 hours and works well (so far).
http://www.beer.org/gallery/Boler17-refresh/IMG_5470
Herb P is offline   Reply With Quote
boler
Need to replace floor in our Boler ursulap Problem Solving | Owners Helping Owners 4 08-09-2009 03:44 PM
New floor in 1977 Boler Neil W' Problem Solving | Owners Helping Owners 2 07-15-2009 07:39 AM
Plywood Floor Replacement 72 Boler Annie T Problem Solving | Owners Helping Owners 5 07-24-2007 10:19 PM
'74 Boler floor help? julian Care and Feeding of Molded Fiberglass Trailers 3 09-20-2006 01:20 PM
Boler 79 Floor Plan General Chat 0 12-31-1969 07:00 PM
