Boler Floor - Fiberglass RV
Old 10-13-2012, 06:07 PM   #1
Trailer: Boler 1700 '79
Boler Floor
I have to replace the sub floor in my Boler so I was wondering if anyone had a thread or info on how to replace the sub floor in a Boler. I need to know how it is secured and fastened to the fiberglass and frame.
Thanks for any help!
Crackedegg is offline   Reply With Quote
Old 10-13-2012, 06:13 PM   #2
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
It is screwed to the frame and fiberglassed to the edges of the shell. Depending on what part of the floor might have to be replaced, it would probally be easier to gut the trailer to do the work. I was lucky and the previous owner had already done the floor replace before i bought my 1971 Boler.
Rick Mooyman is offline   Reply With Quote
Old 10-13-2012, 06:17 PM   #3
Thanks for the response. When I am underneath my Boler all I can see is the shell bottom. So to confirm: the shell was put on the frame and then the floor was bolted to the frame through the shell too? Thanks.
Old 10-14-2012, 06:34 AM   #4
Manitoba
Not sure how it was assembled the first time but to replace the wood floor it is bolted or screwed to the frame and then the edges are fiberglassed to the shell.
Old 10-14-2012, 03:39 PM   #5
Trailer: 1973 Love Bug '13
We have just replaced the floor in our Love Bug. Similar to the Boler but not quite the same, especially the floor. You might try starting here.
Boler floor
I did a search using the forum search engine (use the Google one at the bottom) and use quotes.
Cat futrell is offline   Reply With Quote
Old 10-14-2012, 05:02 PM   #6
Roy in TO's Avatar
Not all bolers are made the same.
PM sent.
Old 10-15-2012, 01:47 PM   #7
Floor again!
Anyone know of Boler's either having a gelcoat on the bottom of the shell or a fiberglass bottom under the floor? All I can see is gelcoat matching the top when looking underneath the trailer. Just picked up some heavy duty jack stands to lift the trailer up on so I can take some photos.
Old 10-16-2012, 03:37 PM   #8
Borden's Avatar
Name: Borden and Carole
Ours has a sub floor of fiberglass with gel coat on both sides then plywood and vinyl on top indoor outdoor carpet has been added on top of this.
A full fiberglass floor
1978 Ontario made Boler
Old 10-16-2012, 03:44 PM   #9
Borden's Avatar
In our Earlton model of Boler the Floor is one with the walls and the skirt below the floor runs back up on the inside to the floor. The gel coat is the same as on the walls a soft yellow/white (the more I use compound on it the more yellow it looks) Maybe same as the bathroom colour.
Old 10-16-2012, 03:53 PM   #10
Ours seems to be one piece on the bottom but I still have a restricted view. I'm having trouble seeing where the wood is fastened to the frame. Any ideas? Thanks
Old 10-16-2012, 06:28 PM   #11
Borden's Avatar
Ours is bolted through floor from above into frame but the linoleum is on top of the anchors/screws
P.S. one piece floor and sides up to middle band
Old 10-16-2012, 06:33 PM   #12
Borden's Avatar
Is yours made out west or is it made in Earlton Ontario Boler works?
boler
73 Boler floor psyber_guy Problem Solving | Owners Helping Owners 0 02-21-2011 09:41 PM
Boler floor astroboy Problem Solving | Owners Helping Owners 16 11-14-2010 06:35 PM
Boler floor jj giger Problem Solving | Owners Helping Owners 2 06-21-2007 08:57 PM
'74 Boler floor help? julian Care and Feeding of Molded Fiberglass Trailers 3 09-20-2006 01:20 PM
Boler 79 Floor Plan General Chat 0 12-31-1969 07:00 PM
