Boler Floor Insulation - Fiberglass RV
Old 04-19-2015, 05:04 PM   #1
Trailer: 1978 Genuine Boler
Question Boler Floor Insulation
Hi all: apologies if this has been answered elsewhere, I only did a quick search and didn't see it so I'll put it out there.
I will be stripping out my 13' 1978 Boler, and when I install a new floor I would like to give it some insulation value. I have tiles for the kitchen area and some laminate flooring I picked up for the rest of it. I was thinking of cutting a 1/8" plywood subfloor so I don't glue directly to fiberglass, then glueing the tiles/laminate to the plywood.
But ... can I put some sort of insulation under the plywood? Foam carpet backing, that tinfoil bubble wrap I've seen, something else? Doesn't have to be much, but I'd like a little something down there.
Any thoughts on any part of this scheme would be greatly appreciated.
rubbie is offline   Reply With Quote
Old 04-19-2015, 05:23 PM   #2
I thought seriously about sandwiching a 3/4" blue Styrofoam insulation panel between the flooa and a sub floor.
Either that or attach (glue) 1" under the floor.
Old 04-19-2015, 07:11 PM   #3
Ian G.'s Avatar
Just remember any extra thickness you put on top of the floor reduces the already limited height inside your Boler.
Old 04-19-2015, 07:38 PM   #4
Yep, Ian, for sure. Good thing both my wife and I are ... diminutive. Compact, you could say.
What might be the best kind of thing to put down? I seem to recall that foam underlay doesn't hold up well over time.
Old 04-19-2015, 07:55 PM   #5
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
Tony, I suggest finishing your floor with the laminate, as you've planned, and then cutting a remnant of carpet to lay over it. You could also put down foam underlayment for additional R value. One advantage is that it will be easy to revert to the original headroom clearance. You can replace the carpet every few years if need be.
Steve
Steve_N_Janna is offline   Reply With Quote
Old 04-19-2015, 08:29 PM   #6
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
In the winter I use the play room/work out room foam mat that looks like a jigsaw puzzle. I take it up in the summer. It works great.
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 04-20-2015, 12:15 AM   #7
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Tony, can't say anything about r value but there have been a number of folks that have installed a bamboo floor and say it is very warm underfoot and holds up very well.
Old 04-26-2015, 05:24 PM   #8
Thanks for the suggestions, all.
I just ripped out the under-bed storage compartments, the lino, and the plywood floor. I'd been smelling something a little funky back there ... it turns out a LOT of water has been seeping in and the plywood was soaked, swelled, and rotting.
The floor is a raised square of fiberglass, with a sunken channel all around next to the walls. I don't see this in other Boler pix I can find. All the channels were filled with swamp water (now drained). Seems like a weird design feature.
I am thinking of glassing over these openings, making for a smooth floor. Any thoughts, or warnings why I shouldn't do this?
boler
Under floor insulation? dylanear Problem Solving | Owners Helping Owners 27 03-01-2016 05:54 PM
Floor insulation jwcolby54 Modifications, Alterations and Updates 20 02-23-2016 07:22 PM
Gelcoating Burro Floor to prolong floor life? not-very-clever Modifications, Alterations and Updates 12 11-23-2013 09:29 AM
Coroplast/Rigid Foam for Floor Insulation Evan Friesen Modifications, Alterations and Updates 14 05-30-2013 10:52 AM
Insulation in 17' Boler Legacy Posts Problem Solving | Owners Helping Owners 1 05-19-2003 05:23 PM
