I was trying to remember what I did with those 1940's Fridges made out of steel with several shelves and a smallish freezer in them when they did not work. I talked to some repair guys at the coast and they said to drop it on there heads and if still not working roll it around the yard.
So after they took a look at it they found nothing wrong and it lit right up for them. I get back to the cabin and while in the truck i try my damdest to
light it and it will not
light. So I did what they told me and dropped it off the back of the truck and rolled it around the yard several times and put it in the cabin and would you believe it the dam fridge lit up first try and I left it running all spring, summer,
fall and in November shut it off for the winter months as it will get down to minus 50*F at times.
So that is what I used to do with the one in the MH finally quits I will have the repair guys check it out and if okay remove the freon or what ever they use in them now and clean the unit including the Exhaust system and keep on using it but if it is not good I will just go and pick up a new one or good used.
Stude
