Boler front bench - cabinet - Fiberglass RV
Old 08-28-2017, 05:00 PM   #1
AKS
Trailer: 1977 Boler '13
Does anyone have tips for attaching that front cabinet door? I have replaced all the hardware in my girl, this one is the hold out driving me nuts! Because the bottom hinge is below the interior storage, I cannot reach to attach a nut or similar, like I have with the others, and a screw grabs 'something' (scary) but does not hold. Its a rather heavy door! Anyone have experience?
AKS is offline   Reply With Quote
Old 08-28-2017, 05:47 PM   #2
Not 100% sure, but I think the hinges on that same door on my Scamp are riveted. You don't have to access the back to install a rivet.
Ours is also loose and awkward to open. Rather than re-secure the door, my eventual plan is to remove the door, trim the fiberglass opening, and put a pull-out drawer there. We do not carry a porta-potty. I will cut the door down to make a lower access panel in the closet.
Old 08-28-2017, 09:37 PM   #3
AKS
Thank you! Thats an idea, but I confess I am scared of riveting! Is it difficult? What kind of equipment do I need? I do keep a Thetford in there, sucker is heavy so a drawer wouldn't work for me.
Old 08-29-2017, 03:12 AM   #4
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
As Jon said the hinge is held in place in my Boler is with rivets. If I had to do it, I would get a thin strip of metal and drill two holes in it to match the hinge. I would then then put the rivet through the hinge, through the fiberglass, and then into this piece of metal to give it more support inside of cabinet.
Riveting is very easy with just the pop rivet gun and rivets to buy.
Place pin into the gun, put rivet into the holes and squeeze the handle till it pops the pin off. Simple.
Old 08-29-2017, 04:48 AM   #5
Borrego Dave's Avatar
Pop riveting is easy. If you have a FG TT it's just maintenance thing you'll have to do once in a while. Pick up a gun and a bunch of aluminum rivets at Harbor Freight and practice on some scrap sheet metal or whatever. After a dozen you'll be at ease with it. One tip if your riveting something with butyl tape. Only draw the rivet down one pull after it grabs and go on to the next one doing the same. That gives the butyl tape a chance to set...ooze a bit. I only give the gun a half pull per rivet after the first pull. Go around like you are torqueing an engine head. They should all pop just about the same on the final pull. On plastic hatches or fittings I draw the rivet down a bit slower so the plastic doesn't crack....so far so good .
Old 08-29-2017, 09:55 PM   #6
aceman's Avatar
Trailer: 13' Scamp and Teardrop
Illinois
Thanks for posting advise on rivet installation Dave. I have pulled the windows on my '79 Scamp due to leaking . I am debating using other types of fasteners because of my inexperience with rivets but after reading your post it gives me a better incite on the installation of rivets.
aceman is offline   Reply With Quote
Old 08-29-2017, 11:45 PM   #7
Rivets are like anything else Ace, you only learn by hands on time and burning a few up with different materials being connected together . Just for reference, aluminum rivets will pop easier and they are all I would use on any plastic work. SS takes a lot more pressure to pop and I would only use SS on metal to metal work. You've got the perfect opportunity now to try a window install with rivets. Best thing is if you find you don't like it, they are easy to remove.
Old 08-30-2017, 12:44 AM   #8
Is there not just a piece of wood in the bottom that you can remove to get access to the bottom? I don't recall having that trouble when I installed a new door. A picture might help. I'm thinking of the closet which might not be what you are talking about.
TimR is offline   Reply With Quote
Old 08-30-2017, 06:13 AM   #9
I believe he is talking about the door on the front bench that hides the porta-potty storage recess. From what I've seen, not all Bolers have that feature.
Old 08-31-2017, 08:09 PM   #10
AKS
She, not he but no, there is no wood to remove, thats where the fiberglass 'bottom' to the storage is, about halfway down the height of the bench.
I remember now why I didn't want to rivet...all my hardware is brass
Old 08-31-2017, 09:22 PM   #11
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I use bamboo barbecue skewers. there's 2 sizes. the typical 1/8 ones or the really large marshmallow ones. I pound the skewer into the old hole, break it off flush and then screw away. It's like screwing into new wood. This also works in the home where I over torqued the door hinge screws and spun them. A pencil sharpener works for making new points on the broken off pieces if you need to do more than one screw.
ststefan is online now   Reply With Quote
boler
front bench-bunk screws??? Timmy T Problem Solving | Owners Helping Owners 0 06-23-2009 05:43 PM
GONE - Front bench from 91 Scamp KamperBob Classified Archives 4 06-20-2009 10:25 AM
Batteries under front bench seats? Rick kl Care and Feeding of Molded Fiberglass Trailers 8 01-11-2009 04:51 PM
Scamp front bench KamperBob Classified Archives 1 07-04-2007 06:07 AM
» Trailer Showcase
BigFoot
flyby
1973 Cloud
Willy
