Boler Furnace Replacement - Fiberglass RV
Old 05-19-2009, 12:04 PM   #1
Trailer: 74 Boler
i have a 1974 13' boler and i need to install a furnace since the old furnace was beyond repair. I am thinking of going with the Everest Star 12,000 btu 12v furnace with a 1.8 amp draw. Has anyone got one of these in their bolers, how do they perform for you? Any feedback would be appreciated, thanks.
Arlyn R is offline   Reply With Quote
Old 05-19-2009, 07:24 PM   #2
Trailer: 1999 Bigfoot 21RB 2500
Hi I just sold my 1974 Boler, I had a stock furnace in It, never worked because I never used it in the20 years that it was in our family I think it just got rusted and then I couldn,t keep pilot light on the old furnace was a 10,000 btu if they work they are great as they dont need any power to run a fan because they are natural rising heat ,the new ones have a fan that is noisy depending on brand but the new ones are much safer all electronic ignition ,if it is a 12000 btu it should be sufficent for a Boler.
Rick and THE BC BIGFOOT............
Rick M is offline   Reply With Quote
Old 05-19-2009, 09:20 PM   #3
Raya's Avatar
Arlyn,
I know I probably sound like a total vulture here , but your defunct furnace isn't by chance a Suburban GT6-3A is it? Tall and skinny? I ask because I have the shell of one with no burner assembly or control. Of course, maybe that's what went out on yours anyway, but I just thought I'd check if you are giving it the heave ho, and perhaps part of it can be recycled.
I hope the installation of your new furnace goes well
Raya
Old 05-19-2009, 09:46 PM   #4
Trailer: 74 Boler
Arlyn,
Raya
Unfortually my old one is long gone, sorry i cannot help on that. By what I read on here complete units or parts are hard to find. Thats why im going new and it sounds the safest since I have small children. I think the new one will work well especially the low amp draw of 1.8 is appealing to me. Good luck finding parts to get yours going. There is probably one somewhere waiting to go to the dump, the hard part is finding that person. Thanks for the reply.
Old 05-19-2009, 09:53 PM   #5
Raya's Avatar
Arlyn,
Thanks for letting me know (I just had to ask).
Raya
Old 07-19-2009, 07:18 PM   #6
Trailer: 74 Boler
I have installed this new furnace in my 13' boler. It works very well and am pleased with it. The draw is 3.4 amps and seems to last well for multiple nights. The electronic ignition is nice with no pilot light and the wall thermostat works very well. It did fit well in the boler without alot to modify. It was worth the money and much safer than the propane heater I was using.
Old 07-24-2009, 02:44 PM   #7
Naomi P's Avatar
Trailer: 1975 13 ft Boler
We're looking at putting a new furnace in our 1975 13' Boler and since I noticed you are also from BC I'm wondering if you could tell me where you got your new furnace? Also which one did you end up getting?
thanks!
Naomi P is offline   Reply With Quote
Old 07-24-2009, 06:10 PM   #8
Trailer: 1970 Boler
Send a message via MSN to Brandon G
hi there, i just finished a total restoration on my 1970 boler. in and out. when i bought the trailer it didnt even have a furnace at all but it had all the propane lines just plugged off. i lucked out and found an Atwood Hydro Flame 12,000 btu. with a little bit of light frame work it fits absolutly perfect on top of the wheel well. It works awesome and heats the little egg in 5 mins then your dying of heat exaustion haha. it also came with a thermoustat which makes it really nice and easy. it performs really well and i would recommend this furnace for the simple reasons that it is quite simple to install with basic tools and it fits excellent with just some very minor ajustments. all in all a great furnace, in my opinion the best bang for your buck.
good luck.
cheers.
Brandon G is offline   Reply With Quote
Old 07-25-2009, 12:23 AM   #9
Trailer: 1973 Compact Jr
Arlyn, I noticed that you had expected the Everest Star 12,000 btu 12v furnace to draw 1.8 amps, but after installation you say it draws 3.4 amps. Do you know why it draws more than you expected?
Thanks!
Dana T is offline   Reply With Quote
Old 07-25-2009, 12:26 AM   #10
Brandon, Atwood makes two 12,000 BTU furnaces, the 7912 and the 8012. I have not been able to determine what the difference is between them. Which did you get?
How noisy is the fan, especially while trying to sleep?
Thanks!
Old 08-16-2009, 09:57 AM   #11
Trailer: 74 Boler
Thanks!
Sorry for the late response. The difference between the 7912 and 8012 furnaces is the btu output for the 7912 is higher. When I ordered the furnace I asked for the 1.8 amp draw 8012 and for some reason I got the 7912 but I decided to go with it anyway. The fan is not that bad for noise, it does not bother me since I sleep right next to it. It keeps it warm and cozy very quickly which if you did not have a thermostat it would roast you out. Hope this helps you. So far im pleased with it and no problems.
Old 08-19-2009, 08:53 AM   #12
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
can I ask what you paid?
I have a fanless original coleman in my SurfSide that works OK but is getting old. I never thought I'd use it as much as I have this year (cold, wet Winnipeg summer) but now I won't go without heat. my other concern is drain on the battery and I worry that it would not last the entire night if it was particularly cool.
thanks
Scott S. is offline   Reply With Quote
boler, furnace
Replacement Furnace - What Type Fits Michelle A Care and Feeding of Molded Fiberglass Trailers 3 04-25-2010 09:25 PM
Boler Furnace Peter Bond Classified Archives 0 08-29-2009 07:50 PM
1970 boler furnace ???? Brandon G Problem Solving | Owners Helping Owners 8 05-18-2009 09:25 PM
Still Looking - Boler 13 foot furnace Kurt in BC Classified Archives 4 03-20-2008 09:29 PM
Boler Furnace Kurt in BC Modifications, Alterations and Updates 16 02-11-2007 07:38 PM
