Boler Furnace won't light - Page 3 - Fiberglass RV
Old 11-15-2008, 08:10 PM   #29
khoa l's Avatar
Trailer: 76 Boler 13 ft
I have not done a voltage check on the pilot thermocouple. I read the instructions above but abit confused on how to do that.
So I should take off the thermocouple, heat the pilot end of the thermocouple and measure current. So with the voltmeter, I should have the + connector hooked to the pilot end of thermocouple and the - connector on the other end while heating the thermocouple..correct?
Am I just measuring any current. Assuming any current means it is working?
How could I check the thermocouple on the thermostat?
khoa l is offline   Reply With Quote
Old 11-16-2008, 12:09 AM   #30
khoa l's Avatar
Question: If there is air trapped in the lines when I turn on the propane tank, would I even get a flame from the pilot light?
The weird thing is that when i disconnect the main gas line running into the furnace and re-install it (which I have done several times now) the furnace will work more often than not.
Old 11-16-2008, 08:02 AM   #31
If I were doing this, this is what I would do.
I would clean the contact end of the thermo couple and the part where it connects to the regulator.
Check for leaks.
Get a hand propane torch. Connect everything back together as described in previous posts.
Light the pilot and if it goes out when U let off the button I would lite it again and put the torch flame on it, wait a couple of minutes and let off the button. If the pilot goes out then, I would take the heater to a qualified repair facility.
Old 11-16-2008, 10:48 AM   #32
khoa l's Avatar
Yes, I am really at the end of my ropes on this...I think I have just about exhausted all that I can troubleshoot, at least on my own. Next stop may be a repair tech.
boler, furnace, lighting, lights, tail lights
Boler Furnace Peter Bond Classified Archives 0 08-29-2009 07:50 PM
1970 boler furnace ???? Brandon G Problem Solving | Owners Helping Owners 8 05-18-2009 09:25 PM
Still Looking - Boler 13 foot furnace Kurt in BC Classified Archives 4 03-20-2008 09:29 PM
13 foot Boler Furnace Kurt in BC Problem Solving | Owners Helping Owners 23 04-27-2007 12:16 AM
Boler Furnace Kurt in BC Modifications, Alterations and Updates 16 02-11-2007 07:38 PM
