Boler Hinges - Fiberglass RV
Old 07-07-2007, 10:57 PM   #1
Trailer: 1977 Boler 17 ft
Hi everyone.
I'm probably missing this in another thread but when we bought our Boler there were no springs on the door hinges and the bushings were badly worn. I have purchased and installed new bushings, springs and bolts from Scamp. I am just wondering about the adjustment of the springs. I am assuming that because there are springs involved they should not be tightened till they are completely compressed rendering them basically useless. Is there a proper procedure for setting them up? I assume they should be left dry to avoid collection of dust etc. caused by lubricant.
Neil W' is offline   Reply With Quote
Old 07-08-2007, 07:25 PM   #2
Brian B-P's Avatar
I basically just tightened them enough to take out the slack plus a couple of turns. I bought the whole kit with bolts from Scamp partially to see what length of bolt they used - I assume it's no longer than necessary, so there shouldn't be a lot of threads past the end of the self-locking nut. The only purpose of the spring and bolt is to keep the door from falling off, such as over bumps, excessive tension will just accelerate wear, and closing the spring up solid will keep the hinge from being able to accommodate hinge misalignment as intended (or as you said, Neil, useless).
I lubricate mine, because it seems to me that brass on aluminum needs grease. My bottom hinge lube dried out, and the door started to stick and creak, and the drag was obvious as the forces cause the body in the hinge mounting area to flex.
Old 07-08-2007, 09:43 PM   #3
Thanks Brian that's about what I had figured. I'm going to think over lubicant but you're probably right that it will reduce wear. Actually it would only take a few minutes every year to clean it and re-lube. A bit of simple preventative mtce. to keep things working smoothly.
Old 07-08-2007, 10:37 PM   #4
Trailer: 73 Boler 1300
My hinges started creaking the other day. Didn't have any grease handy so i gave a squirt of graphite. Instantly stopped the squeak and the hinges move like butter. No unsightly leaks either. I'd recommend it over grease any day.
Yuri Verbowski is offline   Reply With Quote
Old 07-09-2007, 08:27 AM   #5
AND graphite won't attract dust and dirt... which is a good thing as your hinges will last longer without all that grit embedding in the hinges.
Old 07-09-2007, 02:29 PM   #6
Brian B-P's Avatar
Good point: they need lubrication which works under the pressure resulting from the weight of the door (and the spring tension) - not necessarily grease. Maybe graphite lubricant is better.
boler
Replacing hinges on our Boler Dianne Dohei Problem Solving | Owners Helping Owners 10 07-29-2011 12:24 AM
13 ft boler door hinges steve J Problem Solving | Owners Helping Owners 1 09-11-2009 09:01 PM
boler door hinges Brandon G Problem Solving | Owners Helping Owners 3 07-23-2009 10:01 AM
Boler Door Hinges Barbara Gardin Problem Solving | Owners Helping Owners 6 04-10-2006 07:50 AM
Hinges General Chat 0 01-01-1970 12:00 AM
