Boler Hinges!! Help! Need them :) - Fiberglass RV
Old 09-01-2015, 11:08 AM   #1
Hi Friends
I recently bought a boler that has been gutted and boy is it a project!! I didnt realize how hard it would be to get door hinges and really need to set this all up.
Does anyone have either A- number 1 hinges to sell (i have part and only missing smaller half)
Or door hinges as a set??
Thanks so much!
karinnad is offline   Reply With Quote
Old 09-01-2015, 05:35 PM   #2
Raff's Avatar
I believe you can use these. Not sure if the bolt holes line up exactly, but you can likely make it work.
http://www.scamptrailers.com/parts-s...es-detail.html
Raff is offline   Reply With Quote
Old 09-01-2015, 07:08 PM   #3
Boler hinges are two bolt (on the body). Scamp hinges are three bolt (on the body)... there was a reason Scamp wanted more surface area on the body...
Old 09-01-2015, 07:15 PM   #4
Ian G.'s Avatar
As Donna mentioned Scamp hinges can be used but there the hole locations need to be changed, follow my instructions on this post to install the Scamp hinges
Replacing 1974 boler hinges with new scamp hinges
Old 09-02-2015, 04:40 AM   #5
james kent's Avatar
Trailer: Boler 1984
Originally Posted by karinnad View Post
Hi Friends
Thanks so much!
Check out www.fibreglass-rv.com. Paul Neumiester can probably ship you a replacement set.
Old 09-04-2015, 02:41 PM   #6
I tried calling him and i am missing the top number 1 piece, he has the bottoms!
Old 09-04-2015, 02:43 PM   #7
Perfect! Do you have the buttercup boler?? we have been watching yours As long as i know the scamp hinges can be used i will purchase them!
Old 09-04-2015, 06:44 PM   #8
No, the Buttercup Boler belongs to Ian.. and Joan. Don't cause problems with their relationship! I know both of then Hi Joan.
Old 09-06-2015, 06:06 AM   #9
james kent's Avatar
Trailer: Boler 1984
Scamp hinges will work but you will need to drill new holes.
boler
Replacing 1974 boler hinges with new scamp hinges ArneB Modifications, Alterations and Updates 2 08-10-2015 12:39 PM
need help!! Surf-Side tail lights, where can i get them. Evinger1 Problem Solving | Owners Helping Owners 4 04-29-2015 11:20 AM
Need Door hinges or at least where to find them? Kathy Provost Problem Solving | Owners Helping Owners 4 06-01-2010 10:23 PM
