boler propane lines - Fiberglass RV
Old 12-09-2014, 08:39 PM   #1
Trailer: 17 boler
boler propane lines
I was thinking of using flexible rubber hose (propane hose) instead of copper inside the trailer. has anyone ever used it? is it safe, up to code?
i can't use copper to take the sharp corners without creasing
any thoughts?
thanks
andrew78 is offline   Reply With Quote
Old 12-09-2014, 09:10 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Splice in 45 degree or 90 degree elbows.
Dave & Paula
Old 12-09-2014, 09:15 PM   #3
There are fairly cheap automotive tools for bending copper and steel tubing.
Old 12-09-2014, 09:26 PM   #4
Dave & Paula
Yes, and use a flaring tool on the copper lines. It's not a good idea to use ferrule fittings.
Old 12-11-2014, 12:10 PM   #5
Trailer: prolite
Nova Scotia
copper fitting
In Canada I believe or should say it's not allowed to use compression fittings for fuel lines for hookup to a furnace, so would imagine it would be the same for a RV
olde sailor is offline   Reply With Quote
Old 12-11-2014, 12:44 PM   #6
I did residential propane installation for heat and hot water years ago. Flare fittings only, and we used a heavier flare nut referred to as a "frost nut". A search here will bring up previous discussions on this subject. For under a trailer iron pipe is recommended.
Old 12-11-2014, 02:17 PM   #7
They do make a copper propane tubing that is covered with an outer protective skin for direct bury. Contact your propane gas company and discuss it with them.
Old 12-11-2014, 02:18 PM   #8
any thoughts?
thanks
Per National fire code here in the US you can't use rubber hose inside. If using copper you need to use double or single flair fittings. I would check the code in Canada since you live there.
Old 12-11-2014, 09:39 PM   #9
Trailer: 17 boler
i will go with copper. i bought a bender for the tight corners.
thank you for the info
Old 12-20-2014, 07:51 AM   #10
Borden's Avatar
Name: Borden and Carole
Had to do some work and was told no fittings inside trailer except to connection at the fridge stove or water heater, all splits outside under floor? Also some sort of paste/tape for the threads. I am not a gas fitter but did not argue with someone who was.
1978 Ontario made Boler
Old 12-20-2014, 07:54 AM   #11
Borden's Avatar
any thoughts?
thanks
They have a pipe bender that will do a 1" curve and a spring looking pipe bender that work well have both but spring type need to match size of pipe.
boler, propane
17 boler propane lines andrew78 Problem Solving | Owners Helping Owners 0 06-17-2014 09:27 AM
New propane lines in a Boler 13 Raya Care and Feeding of Molded Fiberglass Trailers 25 10-14-2009 02:30 PM
Where to Buy? New propane lines, fittings, etc? Kurt in BC Problem Solving | Owners Helping Owners 9 06-12-2008 05:27 PM
Capping propane lines Peggy Problem Solving | Owners Helping Owners 8 07-12-2007 05:54 AM
Propane lines General Chat 0 01-01-1970 12:00 AM
