Boler Table - Fiberglass RV
Old 09-25-2013, 08:49 PM   #1
Beverly Jones's Avatar
Trailer: 1975 Boler
Boler Table
I don't know about you, but I have one hell of a time trying to sit at the table...I admit I've got an ample rear end and a bit of a middle spread too, but how in the world can one change the table so it either slides back and forth, or is there a way to cut them in half, and fold it up and then down once you're in?
I know I'm not the only one out there with this problem...how have you work this out...besides losing weight.
Thx,
Bev Jone
Beverly Jones is offline   Reply With Quote
Old 09-25-2013, 08:55 PM   #2
Hummm. Parkliner and Escape both build tables that slide that allows people to sit and "shift." However, in my oldly but goody Scamp, right from the factory, I have a two piece table. About a foot was cut off the "table." Which makes dining easy. When I want to convert to a bed, I have that extra piece that fills in. Does this make sense?
Old 09-25-2013, 10:14 PM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I had the small table like Donna, but did not like having to store and place the pieces together everyday, as we do not have a full time bed in our 13' Scamp, so I had made a table that hinged. The small folded up table makes sitting at the bench seats very easy, and we only open it to full length if we have guests. I can even lace up my shoes sitting there.
Good Luck with your dilemma.
Dave & Paula
Old 09-25-2013, 11:01 PM   #4
Brian B-P's Avatar
Originally Posted by Beverly Jones View Post
... is there a way to cut them in half, and fold it up and then down once you're in?
To me, this sounds like you might want to split the table lengthwise, so it is long and narrow leaving more space between table edge and seat edge... the opposite direction from the style Dave and Donna described.
The root of the problem for some people is that the table has to match the space between the seats in width, so it can serve as part of the bed platform. That leaves the table edge directly above seat edge, which may be too close for some. One way around this is to cut the table down in width to whatever is comfortable (or hinge the edges), and carry a separate one-piece board to fill in the space for bed use.
Old 09-26-2013, 09:45 AM   #5
We also made the table fold in half to make more space to move around in the trailer.
OurBoler.com 74 Boler rebuild
Nelmes is offline   Reply With Quote
boler
Boler Table Bolt Grantz Problem Solving | Owners Helping Owners 4 04-03-2016 07:53 AM
Table in Boler - Anyone Ever Painted w/ Shiny Sealant? BCAlli Modifications, Alterations and Updates 10 04-18-2012 12:44 PM
What to do with table when driving (13-ft Boler) skryabin Towing, Hitching, Axles and Running Gear 8 09-23-2011 09:35 PM
1972 boler 13' table size sczweifel Modifications, Alterations and Updates 0 09-23-2011 09:01 PM
