Boler-to-frame fasteners -- I'd like advice on how to replace them - Page 2 - Fiberglass RV
Old 05-22-2009, 08:34 PM   #15
Trailer: 1973 Compact Jr
If you use U-bolts you should have a saddle on the frame to keep the U-bolt from crushing it. Because the part of the U-bolt that actually touches the tubular frame member is very narrow it is easy to crush the tube.
Also, unlike screws or bolts into the frame, a U-bolt only holds the two items together, but does allow them to slide along the length of the tube.
Finally, for those thinking of drilling all the way through the frame and using a bolt, tightening the bolt will tend to crush the tube, squeezing it like a soft drink can. That's why they used screws in the first place -- tightening the screw does not significantly distort the tube.
Dana T is offline   Reply With Quote
Old 05-19-2015, 07:45 PM   #16
Has anyone used new larger screws to replace old/loose ones? If so what size is recommended? Do you just go in the same spots as the old ones?
carlosperez is offline   Reply With Quote
Old 06-12-2015, 12:47 PM   #17
bullfrogeh's Avatar
I've just today retrieved my '73 Boler frame from the 'sandblasting and paint' shop. Mine (Earlton built) was originally fastened to the fibreglass body with 14 'lag-type screws'. I have also welded four secure angle brackets, one near each 'corner' of the overall body-to-frame mounting areas, and will thus 'bolt' the body to the frame, using appropriate large weight bearing washers. I will also replace most; but not all, of the mounting screws, for additional security.
Am I on the right track ? further advice would be graciously appreciated !
bullfrogeh is offline   Reply With Quote
Old 06-12-2015, 01:11 PM   #18
bullfrogeh's Avatar
I have welded on four pieces of 1/4 inch angle-iron to the frame. one near each body-supporting corner, each with a drilled bolt hole. I now plan to 'bolt' the fibreglass body to the frame. I will also replace most of the original 'screws'. I am also leaning towards 'Lisbeth's concept of a 'U-bolt' structure for further security at each corner.
I sincerely appreciate the 'advice' and ideas I've gleaned from this site. Tanksalot !
And, of course, further advice is always appreciated !
boler
Flooring and Frame Paint Advice? Jeff Nightingale Problem Solving | Owners Helping Owners 24 09-15-2009 05:55 PM
Bigfoot body shifted on frame... advice? Bruce & Melissa L Problem Solving | Owners Helping Owners 16 08-17-2009 11:01 AM
Need to replace floor in our Boler ursulap Problem Solving | Owners Helping Owners 4 08-09-2009 03:44 PM
New Frame for a Boler Cheryl Lee Problem Solving | Owners Helping Owners 2 01-28-2008 09:13 AM
Boler Frame RobJ Modifications, Alterations and Updates 6 03-19-2007 03:16 PM
