Boler water heater - Fiberglass RV
Old 07-30-2019, 12:31 AM   #1
Saskatchewan
Boler water heater
Hello all,
So I’m running a 1980 17’ Boler these days (4th Boler).
I’m having issues trying to get my hot water heater going.
There doesn’t seem to be any gas passing from the main valve.
There’s certainly LP to the stove and the stove and HWHeater are fed off the same supply line.
I priced-out a new valve at ~$250.
I believe I could install this all right, but there’s no guarantee that the HWH will even work afterwards.
I tried to break into this valve, but was unsuccessful.
Any thought, tips or prayers?
Also, where can I pickup a Boler sticker package? How much do they run?
FCCC27C3-051E-4C00-8924-1EAE8DDF31AC.jpg   E8005A05-1EBA-4B86-A66C-44D693C56213.jpg
SK_Boler_Cpl is offline   Reply With Quote
Old 07-30-2019, 06:20 PM   #2
Trailer: !977 KingsleyGMC, 1968 Bailey Mikado
Nova Scotia
Originally Posted by SK_Boler_Cpl View Post
Hello all,
You most likely need a $20.00 part .Does the pilot light come on when you hold the button in? If it does and goes out immediately when you release the button, you need a thermocoupler...available anywhere.
panhead_mike is offline   Reply With Quote
Old 07-30-2019, 10:25 PM   #3
Saskatchewan
No - I mean there is no gas
You can hang a match under the venturi all day if you want - aint nothing gonna light.
I was going to order a new thermocoupler anyway if I replaced the valve.
No - there is gas going into the valve, and no gas coming out of the valve.
I can replace the valve, no problema. It's just if I do, I might find-out the HWH is shot anyway.
The question is, spend the $300 tax-in on the valve/thermocoupler and take the chance the HWH isn't burned-out.
Is there anyway to tell if a HWH is likely to work, short of firing it up?
Old 08-05-2019, 05:20 PM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Not trying to be a smart aleck, but you turned the small knob to pilot, pushed it down and held it with a match on the pilot? It can take 3-4 minutes for the gas to make it through the system if nothing else is running on gas
Joe
Old 08-05-2019, 05:46 PM   #5
Saskatchewan
Thanks guys - no offense taken.
It's my 4th Boler - so I know my way around them alright.
The good news is that I got the gas valve working AND the HWH working. Working like a hot-damn, actually.
It's all good.
-John
boler
How do I drain water from the hot water heater? whoot Care and Feeding of Molded Fiberglass Trailers 50 05-02-2021 11:46 PM
Boler water setup??? new tank, pump & water heater question Johnny M Plumbing | Systems and Fixtures 7 05-07-2015 12:41 PM
Coleman Hot Water Heater outside a Boler kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 06:11 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
