Boler Wheel and Tire - Fiberglass RV
Old 09-22-2011, 04:03 AM   #1
Trailer: 77 Boler
Newfoundland
Hi,Was going to upgrade my Boler wheels from the 12's that were on it when I bought it to a nice set of 14's I have.Any body using 14's and if so what size tires would you recomend as to not hit the wheel wells or anything.
Thanks Craig
67dodge is offline   Reply With Quote
Old 09-22-2011, 05:40 AM   #2
Craig, does your Boler have the original axle? That may make a huge difference. How much fist bump room do you have using the original tires and wheels?
Old 09-22-2011, 09:50 AM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
...not all trailers (even ones of the same species) sit at the same height and therein lies the issue. If you can or cannot go to larger wheel/tire size will depend on this opening size.
Our Trillium sits high enough to enable the use of 14in. aftermarket (automotive) rims and 6 ply truck tires. Check out the wheels n rims in my trailer profile shown here.
Old 09-22-2011, 10:22 AM   #4
Trailer: Fiber Stream
Check out Restoring Our 1972 Boler American, especially post #19 on page 2.
Roy in TO compared three 13" wheels and the tires are all different diameters.
Old 09-22-2011, 05:42 PM   #5
Trailer: 77 Boler
Newfoundland
Wow ,sure is a lot of info on tires there Frederick,Im am using the original axle,so it looks like the 14's might be out of the question.I guess that's why the guy had Princess auto 12's on it ,They were close to the original 13's.I'll have to size it all up when I'm ready for wheels.right now its sitting on 10's cut out of 3/4 steel plate to get it into my Garage.
Thanks everyone for the help
Craig
Old 09-22-2011, 05:50 PM   #6
Trailer: 77 Boler
Newfoundland
Restoration Update
Here's a couple of pics of our progress,It's a long and winding road but we're getting there,It'll be worth it in the end.....
Old 09-22-2011, 06:47 PM   #7
Sheryl's Avatar
Trailer: '99 Casita 17'LD
Montana
I'm having trouble locating rims for my Boler--13", 4lug, 4". No spare at this point so I just bought two 12" wheels and tires at a farm implement store. My plan is to use them as spares until I find a 13" wheel (been told I can do this if I drive slowly, like a doughnut spare). The slight difference in height is enough to let me get the Boler into my garage (hence, the reason for two).
Sheryl is offline   Reply With Quote
Old 09-23-2011, 06:54 AM   #8
james kent's Avatar
Trailer: Boler 1984
For a long time, until I found a proper sized 13" tire and rim, I carried a 15" temporary doughnut for a spare. It was almost the same height as my 13" trailer tires and can be found at parts yards for $5 or less.
Old 09-23-2011, 07:40 PM   #9
Borden's Avatar
Name: Borden and Carole
13' is so light; our 17' has st205r14 75C tires 'C rated' but came with B rated original tires
1978 Ontario made Boler
Old 09-23-2011, 08:44 PM   #10
My Fiber Stream has 12" wheels
My Fiber Stream has always had 12" wheels. I've towed it for 7 years and I'm guessing over 20 or 30 thousand miles with only 1 blowout. I believe that having 4 wheels (double axles) might mitigate the smaller wheel size, but I don't fear using them. I always drive 55 mph when towing.
boler
Tire and Wheel Bearings Question Doug1234 Towing, Hitching, Axles and Running Gear 4 09-11-2011 05:34 PM
Boler Tire / Wheel Question Peter_Crowl Care and Feeding of Molded Fiberglass Trailers 8 05-07-2011 03:06 PM
Snow tire chains / Bigfoot 17CB wheel clearance breid19 Towing, Hitching, Axles and Running Gear 9 02-17-2010 11:18 AM
Scamp Tire wheel upgrade? Nolan Scheid Towing, Hitching, Axles and Running Gear 5 09-18-2007 06:27 PM
Tire & Wheel william russell Classified Archives 0 10-29-2006 11:54 AM
