Boler wheel bolt change to studs - Fiberglass RV
Old 12-01-2011, 12:39 PM   #1
I am renovating a '79 13 ft Boler and wish to change the wheel bolts to studs so I can use lug nuts. I tried a search on this forum to no avail. Has any one done this and if so, how. Thanks
wayneinbc is offline   Reply With Quote
Old 12-02-2011, 05:07 PM   #2
An auto parts store should have wheel studs and nuts. Check that the studs don't stick out through the back of the hub too far and hit something, and be sure that the nuts tighten on the wheel before they hit the shoulder on the stud. Double nut the stud, tighten them together, to install the studs, some loctite on the hub end of the studs would be a good idea.
boler
Boler Table Bolt Grantz Problem Solving | Owners Helping Owners 4 04-03-2016 07:53 AM
Scamp wheel bolt pattern Brian Bran Towing, Hitching, Axles and Running Gear 6 05-08-2011 05:39 PM
Change to the Wheel Bearing Workshop ERIC B. Oregon Gatherings 0 07-03-2010 03:04 AM
Change my Boler frame Jayson Wall Problem Solving | Owners Helping Owners 0 05-12-2009 06:57 PM
Bigfoot 5 bolt wheel rim dimensions? Ken Vernon Problem Solving | Owners Helping Owners 0 10-03-2008 04:45 PM
