Border Collie Damage to Casita Door - Page 2 - Fiberglass RV
Old 01-27-2010, 02:44 PM   #15
RobertaF's Avatar
Trailer: Casita Spirit Deluxe
From what I am seeing there I would want to take the door apart, and repair the fiberglass outer skin from the back side (there would still be cosmetic repair needed on the outside of course). Reinforcement could be added at the same time, so that a similar pull in the future would be much less likely to cause the same problem.
Raya
Thanks Raya. There is just some sort of hard foam insulation looking stuff inside the door, nothing to really fasten anything to so if we reinforce we are going to have to put something in that will fasten down from side to side. Not too sure yet what to use. I may give Casita a call to see what they suggest. They are so pricey with replacement parts sometimes that I rather dread even asking in case they say we should replace the entire door (Oh, surely not that...imagine the cost of shipping?)
RobertaF is offline   Reply With Quote
Old 01-27-2010, 06:37 PM   #16
Roberta, I don't know where in California you're located... but, you may want to check out RV Doctor George for a new (used) door. It may be easier to just replace the entire thing:
RV Doctor George
Old 01-28-2010, 09:36 AM   #17
RobertaF's Avatar
RV Doctor George
Hi Donna,
We're in the high desert in Southern CA. I note that RV Doctor George is in Sacramento. Have you had dealings with them?
I called Casita yesterday and they said I didn't have many choices. I think they may buy the doors themselves since it didn't sound like they had any of that outer skin for sale. They said I could take it to a boat place and have it repaired or buy a new door - about $150. I forgot to ask but I wonder if that is without a window in it...that would make it lighter to ship.
I'll give RV Doctor a call and see what they have to say. I'm at the point that I'm wondering if a new door might not be the easiest thing too. Taking that door completely apart to do a proper repair looks like it will be quite a job.
Thanks~
Old 01-28-2010, 06:04 PM   #18
Raya's Avatar
Roberta,
When I say "reinforce," here is an example of what I mean. (I'm not looking inside your particular door, so this is more general.)
1) Separate inside and outside of door, so you have two fiberglass skins (or, alternatively, cut a large opening in the inside skin, if it is going to be covered by carpet or etc. anyway).
2) Patch outside door skin from the back (inside) with fiberglass cloth and epoxy resin.
3) "Reinforce" outside door skin from the back (inside) with something such as more layers of fiberglass, or a piece of pre-made fiberglass board (say, 1/4" to 3/8" thick and 8" x 14", for example).
4) Put door back together
5) Repair gelcoat on outside of door.
6) Remount holder-opener hardware, running fasteners through new reinforcing block
Note that depending on strength of door and hardware mounting, it may go through both door skins. In this case you would want the reinforcing block to fill the space between the skins (thickened epoxy, for example) and then the fasteners would go all the way through.
Raya
casita
Frost damage? Wilder Care and Feeding of Molded Fiberglass Trailers 4 12-06-2009 08:48 AM
Casita Door Lock Bob Starr Problem Solving | Owners Helping Owners 0 09-12-2009 07:58 AM
Casita Door Lock Bob Starr Care and Feeding of Molded Fiberglass Trailers 0 09-08-2009 08:24 AM
Does this look like water damage? Rebecca H. Problem Solving | Owners Helping Owners 14 07-16-2007 11:14 PM
Fiberglass damage and dry rot Andrea in Oregon Problem Solving | Owners Helping Owners 17 02-14-2007 11:50 PM
