Bottling up electrical connections - Fiberglass RV
Old 04-06-2019, 09:31 PM   #1
Trailer: In the market
Talking Bottling up electrical connections
Keeping the "shore power" plugs dry here in the Pacific Northwet can be challenging. Here's a simple thing that seems to work pretty well. Cut the bottom out of a 2 Liter Mountain Dew bottle (must be MD or it won't work... ;-) Make a slit up one side terminated just before it necks down toward the lid, and cut a few short cuts to make an asterisk * shape at the end. Slide it over the cable and voila` instant umbrella. Hope this helps someone.
Yellowjacket is offline   Reply With Quote
Old 04-06-2019, 10:27 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Nice fix Anthony and thanks for the heads up on a MD bottle. I've got a couple Coke bottles but they must not be up to the amps .
Old 04-07-2019, 09:29 AM   #3
Trailer: 2008 Casita 17 SD
Sorry, but honestly, I think that looks really tacky.
Why not just get something made to do what you're trying to do. Like these...
https://www.amazon.com/Cord-Connect-...SIN=B0092P32HC
Old 04-07-2019, 09:30 AM   #4
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
Got to agree w/Gregg
Not for me but it does give me some ideas
Old 04-07-2019, 10:06 AM   #5
Trailer: 2019 Scamp 13' with 2015 Nissan Frontier V6
Alabama
This is a good idea. I've been looking for a way to rainproof the connection. None of the manufactured covers I have found have been big enough to hold the plug that comes on the camper.
Vicki Hale is offline   Reply With Quote
Old 04-07-2019, 10:21 AM   #6
Of course, that can be changed too. I installed a Marine style 30 Amp twist lock male power inlet and a cord which just plugs on and twists to lock up. They also make them for 20 Amp regular "house style" plug ends as well. Just cut the end off inside and attach it to the screw terminals of the outlet.
Old 04-07-2019, 11:10 AM   #7
Massachusetts
I don't know if that is a good idea Anthony. That green cable does not look like it could handle 30 Amps, and why would you need an extension like that.
I'd think twice about using a set up like that. Does not look safe to me.
Just my 2 cents worth.
Lockman is offline   Reply With Quote
Old 04-07-2019, 04:23 PM   #8
Trailer: Casita 17'
Love it! Great idea. Sure would get a guy out of a bind.
dblcola is offline   Reply With Quote
Old 04-07-2019, 04:28 PM   #9
One way to keep the plugs dry but it looks like you are using a 20 amp extension cord with a converter type plug for your 30 amp service. Not a good idea if using more than lights. The bottle set up would work for a 30 amp extension cord also.
Old 04-07-2019, 04:29 PM   #10
I've got some of these cord protectors but they seem to fall apart and they are not water proof.
Old 04-13-2019, 10:09 AM   #11
Trailer: scamp
Indiana
And they are not big enough. :-(
computerspook is offline   Reply With Quote
Old 04-13-2019, 10:14 AM   #12
Trailer: scamp
Indiana
Yeah and tool boxes.
I have done that a number of times.
1 liters will work pretty good for regular cords. And if I have to make junction out in the field to hook my 30A extension to my 30A plug for my scamp I use a tool box. I have a tool box I use to hold the blocks for leveling my scamp. It has notches in the ends. I run the cords through the notches, connect the plugs and then close the box. Get a bit of water in the bottom, but the connection stays dry.
Old 04-13-2019, 10:36 AM   #13
Trailer: 2011 KZ Sportsmen 242SB / 2004 Ram-Cummins 2500 2wd
I have a plastic 14" tool box that I use to carry a standard RV water pump (used for obtaining fresh water from lake/river to fill transfer vessels), but never thought of modifying it for cord connect weather shielding.
Another job before season start!
Note: Our 30 Amp RV plug-in at home is fed by a 20 Amp Breaker and 20 Amp GFCI (because of wire size and proximity to grade). It's totally legal and adequate, unless I get stupid and try to operate all the 120 Volt appliances at the same time, at which time it will 'pop' the feed breaker, protecting the wire, which is the limiting factor on max breaker sizing. I also have a second circuit (20 Amp GFCI) at the diagonally opposite corner of my garage, that can service another RV, if needed.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
Old 04-13-2019, 04:32 PM   #14
gotta wonder....
why not stuff both plugs just inside and close that lid with the cut-out/slide that's already there ? (???).....I must be missing something
electrical
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Bill K
Protecting crimped electrical connections frank_a Electrical | Charging, Systems, Solar and Generators 14 08-04-2014 12:21 AM
Campground electrical connections??? Doug Mager Problem Solving | Owners Helping Owners 18 07-28-2010 06:33 PM
6 Volt Battery Connections VIDEO kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 04:28 PM
Gray water fittings and connections? Roy in TO Plumbing | Systems and Fixtures 4 06-02-2008 11:52 PM
Battery Connections dlehman Problem Solving | Owners Helping Owners 19 05-19-2007 09:19 AM
