Brake Controller - Fiberglass RV
Old 08-20-2007, 08:04 PM   #1
Trailer: 1989 17 ft Bigfoot Deluxe / 2004 Ford Ranger
Just bought a new tug, an '04 Ranger 4x4, and it came equipped with a tow pkg...yahoooo......(trans. cooler, Class III hitch, 7-wire harness, and brake controller)
Now, the controller is one I've not heard of before...it is marked "ACTUATOR", no other identifying letters or wording. Very basic;a small lever slides across a horizontal scale, and a red 1"square raised pad sits to the right, likely for manual application of braking. No sign of the usual "time & power" adjustments.
Does anyone use one of these units ? Who is the mfr ? Are they reliable ?
This truck spent the first three years of its life in Maryland, I have found out.
Any info would be appreciated...a photcopy of an owners manual would be super !
Joe
Joseph Olajos is offline   Reply With Quote
Old 08-21-2007, 05:47 AM   #2
Roger H's Avatar
Joe, it sounds to me like any one of the less expensive ramp-type brake controllers. Since all the wiring is already in place, it would be a really easy and quick switch to install a Prodigy. It's definitely worth the time and effort.
Roger
Old 08-21-2007, 11:23 AM   #3
Brian B-P's Avatar
I'm with Roger on this one. Even if you could find the maker, if it is not adjustable it cannot be a proportional controller, and thus I don't think it is worth using.
Old 08-21-2007, 11:55 AM   #4
Dave Mac's Avatar
Trailer: Burro 13 ft 1979
If you are going to buy a new controler chack out the "Tekonsha P3". Realy a nice set up. I got one a month ago and it is fantastic and very easy to set.
http://www.fiberglassrv.com/board/index.ph...st&p=235848
Dave
Dave Mac is offline   Reply With Quote
Does tug need brake controller Thelma & John Towing, Hitching, Axles and Running Gear 6 06-16-2009 11:54 PM
Brake Controller Gary Seronik Towing, Hitching, Axles and Running Gear 10 05-06-2008 03:13 PM
Brake controller Dan Simon Problem Solving | Owners Helping Owners 8 07-30-2006 02:57 PM
Brake Controller JOHN PAUL EVANS General Chat 0 05-03-2006 11:52 AM
» Trailer Showcase
Fuzzy
paulaj
Tardis
BPS
