Brake Lights, Turn signal lights, marker lights, oh my! - Page 2 - Fiberglass RV
Old 11-18-2012, 02:59 PM   #15
It appears that Etrailer recommends that you also should use the above listed product with the following part. I am not sure I entirely understand why, but maybe this is where Frederic wend wrong? Thoughts?
Tail Light Isolating Diode System with Wiring Harness Hopkins Tow Bar Wiring 38955
...or maybe this is just a towbar issue that only comes up when you pull a car ?
glamourpets is offline   Reply With Quote
Old 11-18-2012, 03:14 PM   #16
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I think that the diodes isolate the two vehicles electrical systems. For a trailer, just the adapter module should do the trick.
Old 01-02-2013, 08:45 PM   #17
Trailer: Fiber Stream
Red face It took me HOW LONG to figure it out???
Frederic claims the adapter didn't work. It MIGHT be an issue of incorrect wiring.
Is anyone else using this unit successfully?
If there's a screwed up way to do something, I'll find it first!
Originally Posted by Thomas G. View Post
Output
  • One wire goes to the brake lights.
  • One wire goes to the left turn signal
  • One wire goes to the right turn signal
I think the module's internal circuit senses when both turn signal wires are powered and diverts the power to the brake lights. When just one side is powered (for turn signal) it passes the power to the appropriate light. When you step on the brake, the module clicks, indicating a mechanical relay inside.
All I cared about were the turn signals. I never connected an actual light to the output brake wire. Once I added a concealed brake light near the terminal strip inside, the turn signals work perfectly!
Old 01-03-2013, 05:46 AM   #18
Thomas G.'s Avatar
Great news. I wouldn't feel bad about it, as I don't recall the instructions saying that all three wires need to be connected for it to function. And it is a black box, so who knows the exact logic of the circuit?
Old 01-03-2013, 06:34 AM   #19
Raz
Raz's Avatar
Vermont
I'm curious, is there a delay between the time the tow vehicle turn signal starts to work and the trailer turn signal starts to work? Raz
Old 01-03-2013, 09:10 AM   #20
They appear to be simultaneous.
lights
Marker lights on Deb & Chuck Problem Solving | Owners Helping Owners 47 10-23-2012 01:40 PM
Marker lights AND reflectors? shelley w Problem Solving | Owners Helping Owners 4 06-24-2012 11:32 PM
Brake/Turn Signal Lights Red-Dwarf Problem Solving | Owners Helping Owners 7 05-15-2012 09:54 PM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
Side marker lights Maggie O. Problem Solving | Owners Helping Owners 10 06-12-2006 03:18 PM
