Brake/Turn Signal Lights - Fiberglass RV
Old 05-15-2012, 03:20 PM   #1
Trailer: 1979 13' Boler
We hooked up our Boler the other day to get her ready for camping and when I tried the lights, the brake lights work fine, the hazard lights work fine and the left turn signal works fine, but the right signal doesn't work, except when the brake is on as well. My utility trailer lights work fine, so I know the problem isn't in the TV.
Can someone point me in the direction of where I might look to find the fault?
Thanks,
Noel
Red-Dwarf is offline   Reply With Quote
Old 05-15-2012, 03:43 PM   #2
Noel if you have a little bit of corrosion of any kind on the tow plug & or the trailer side it can give you strange results.
Old 05-15-2012, 03:44 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I would check the bulb socket for rust and clean with fine sand paper,then very light coating of grease. Good luck.
Old 05-15-2012, 03:55 PM   #4
IllAnnoy
Check the lights again with the lenses off, the right side may be finding a ground through the other element when the brakes are applied.
If so check the ground at the right side light.
Old 05-15-2012, 04:05 PM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
To make life easier from now on, I'd run a ground wire from the wiring plug at the tongue to the brakes and to each tail light. The wire is only a few bucks, it is relatively easy to run and it eliminates future headaches.
Thomas G. is online now   Reply With Quote
Old 05-15-2012, 04:08 PM   #6
Is there a way to test the lights without the TV attached?
Old 05-15-2012, 05:12 PM   #7
IllAnnoy
Simply use a battery or charger with a couple of probes so that you can inject power into each function separately. Bear in mind that each brake light is powered by it's respective turn signal wire. and fourways are are both turn signals. The exposed terminal on the fourplug is the ground.
Look here...
Trailer Wiring Diagrams | etrailer.com
Old 05-15-2012, 09:54 PM   #8
Trailer: Fiber Stream
Lightbulb Either Store-Bought or Home-Made
  1. Westhaver Associates, Inc. "flashCube"
  2. Emergency flasher
lights
Scamp13 signal and brake light issues R Drayer Problem Solving | Owners Helping Owners 10 04-15-2012 07:26 AM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
Back to tackling that missing left turn signal... Bobbie Mayer Problem Solving | Owners Helping Owners 16 09-08-2007 11:01 AM
13' Scamp - Left turn signal and brake light Kate Carney Problem Solving | Owners Helping Owners 7 07-23-2007 08:55 AM
brake/ turn light/ AC stan s. Problem Solving | Owners Helping Owners 17 07-01-2006 07:03 AM
