Breakaway Switch - Fiberglass RV
Old 10-02-2010, 08:16 AM   #1
Trailer: 1980 16 ft Scamp (Restored)
Breakaway Switch
I installed a breakaway switch, wired it (per instructions) to battery positive and brake wire. When I jacked up the trailer, spun the wheel, pulled the breakaway, it never locked up the brakes. Of course I had the T.V. electrical disconnected, (per instructions.) Any ideas?
Lawrence W is offline   Reply With Quote
Old 10-02-2010, 08:36 AM   #2
floyd's Avatar
Did you check to see if they will lock with the controller?
Old 10-02-2010, 09:56 AM   #3
Check the brake adjustment.
Bill K
Old 10-02-2010, 10:45 AM   #4
They seem to work fine with the controller. They may need fine tuning.
Old 10-02-2010, 11:19 AM   #5
Roy in TO's Avatar
What is your battery voltage?
Old 10-02-2010, 11:58 AM   #6
Chester Taje's Avatar
Are you sure you have manually activated the break a way switch properly.
Old 10-02-2010, 03:04 PM   #7
Originally Posted by roy in to View Post
what is your battery voltage?
12.6v
Old 10-02-2010, 03:06 PM   #8
I pulled the disconnect out of its slot...that's all.
Old 10-02-2010, 08:11 PM   #9
Perry J's Avatar
The switch should work independently of the brake controller.
If you lose the trailer and activate the switch your not going to be hooked to the TV.
When you remove the plug you send 12v directly to the brakes.
Run a ground wire directly from the battery, -post, to the trailer frame and see if that solves your problem.
John
Old 10-03-2010, 06:53 AM   #10
Joe Z's Avatar
Test the wire back at the brake drum to see if it's energized when you pull the pin
Joe
Old 10-03-2010, 01:35 PM   #11
I SOLVED THE PROBLEM! (with a little help from you all). It was a bad connection between the brake wire and the breakaway wire. This time when I pulled the plug, the brakes locked up.
Thanks again for your advice.
Breakaway switch cable snapped paulitzlee2 Towing, Hitching, Axles and Running Gear 11 08-22-2010 09:22 PM
Breakaway switch - do I need one? can I even get one? Shelley Towing, Hitching, Axles and Running Gear 1 06-30-2010 04:03 PM
Scamp 16' installing breakaway switch Carol H Towing, Hitching, Axles and Running Gear 23 04-17-2007 05:49 PM
Wiring Brakes & Breakaway Switch Victor Benz Towing, Hitching, Axles and Running Gear 9 07-30-2006 07:53 PM
Breakaway brake switch Rich McCormack Problem Solving | Owners Helping Owners 7 04-22-2006 08:59 AM
