Broken Dometic Fridge - Fiberglass RV
Old 05-29-2012, 11:20 PM   #1
Trailer: Trillium 1300
I have a 1974 Trillium 1300 with a Dometic fridge that is no longer working. I would like to remove it so I could take it to get serviced, and if completely dead, can replace with something newer. I am having trouble removing it. Can anyone tell me what the magic trick is. Are their any hidden screws I am not seeing?
Moondogyaz is offline   Reply With Quote
Old 05-30-2012, 03:13 AM   #2
Raz
Raz's Avatar
Vermont
You might find a manual with installation instructions in the Document Center. Left column under Resources. Good luck, Raz
Old 05-30-2012, 09:04 AM   #3
Perry J's Avatar
Trailer: 16' Casita
There may be a screw into the floor in there rear of the refer.
When you get it out you might turn it upside down for about 24 hours and then try it.
Sometimes this helps on older units.
John
Old 05-30-2012, 10:32 AM   #4
Victor Benz's Avatar
What John said. My Dometic has 4 screws in the front, and three in the bottom at the back, accesible through the lower vent door. Also disconnect the propane line, and the power plug in, if you have one. Then it should pull out from the front, into the trailer. They can be quite heavy, those older refers.
Vic
Victor Benz is offline   Reply With Quote
Old 06-02-2012, 07:17 AM   #5
sparky1's Avatar
Trailer: Casita patriot deluxe (sold)
Virginia
1. on the outside---is there Yellow Liquid at the bottom./.can you smell Amonia? if so it completely gone.
2. maybe (on electric) just the heating element is bad
3.Does the propane flame burn? does that portion work?
4. i took one out for a friend did the (BURP) solution, upside down 24 hours,, back in place 24 hrs.. worked fine for 2 more years. unit needs to be level to Work correctly on (OLD UNITS)
my 2 cents sparky1 in s.Va.
sparky1 is offline   Reply With Quote
fridge
Dometic Fridge - Again thostorey Problem Solving | Owners Helping Owners 7 09-23-2011 06:44 PM
dometic fridge Paul from NWOnt General Chat 0 08-12-2007 06:57 PM
Dometic fridge Paul from NWOnt General Chat 7 08-08-2007 08:40 PM
Dometic Fridge bdiscount Problem Solving | Owners Helping Owners 12 06-26-2006 01:01 PM
3 way Dometic fridge Laura Heiman Classified Archives 0 03-31-2006 09:14 AM
