broken window panel - Fiberglass RV
Old 05-10-2014, 09:59 AM   #1
broken window panel
I broke a window panel on my trillium 76 ,13'.
I can have a new panel for it , but is there a technique to fit back with the rubber liner the glass into the aluminium frame?
Thanks
Philippe
Philippe is offline   Reply With Quote
Old 05-10-2014, 11:54 AM   #2
Bananaman's Avatar
I had the same issue and found a complete used replacement window through Joe at Trillium Outback in Calgary.
Much easier to replace the whole window, and the cost with shipping was around $100. Might want to check with them ... google trillium trailer (I'm not sure if I can paste the link )
Ken
Bananaman is offline   Reply With Quote
Old 05-10-2014, 01:24 PM   #3
Ian G.'s Avatar
Glass companies often use a glazing tape which is attached around the glass then inserted into the aluminum frame. If you want to keep it original Vintage Trailer Supply sells the "U" gasket.
Small U Gasket
Old 05-10-2014, 01:32 PM   #4
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thanks
Philippe
I just had this done recently, though I wimped out and had the glass guy do the work. (Just removed the whole single louver section and dropped it off). I've snookered myself before into thinking I had measurements right only to get home with the wrong sized piece and now prefer to let them make the measurements etc. Cost about twenty bucks, and they did a great job.
Per gasket:
My gasket was in perfectly sound condition despite being original and thus almost forty years old. I requested that they reuse it if possible. They did so, no problem.
One more vote for the superior quality of at least some materials used way back when!
Old 05-12-2014, 09:57 AM   #5
David Tilston's Avatar
Which window do you need the pane for?
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
broken window latch ThomasE Problem Solving | Owners Helping Owners 1 08-09-2011 12:59 PM
Broken window pane on boler... mikedup Problem Solving | Owners Helping Owners 8 04-18-2011 07:18 PM
Broken side window Roy Hedahl Problem Solving | Owners Helping Owners 3 08-30-2007 07:52 AM
Broken Burro Window David Joseph Problem Solving | Owners Helping Owners 23 02-18-2007 09:28 PM
